volume displacement
volume displacement
Message 1 of 8
volume displacement
hi ... when i use polygon object with volumestandard shader the displacement inside the shader tab does not work ? .. so i have to use the normal displacement slot in the shadergroup for polys ? .. or is there a trick ?
thank you
Replies (7)
Message 2 of 8
lee_griggs
Here is an example shading network of a displaced object, rendered as a volume.
You must ensure you have enough Volume Padding to see the displacement.
You could alternatively try using the Displacement attribute on the Standard Volume shader.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 8
can you export the displaced volume as geometry and render it in a separate program?
Message 4 of 8
lucasridley
@LeeGriggs, I've seen Volume Padding mentioned several places but nowhere does it mention or show a screenshot of where it's actually located in Maya. I can't find it anywhere. I'm just trying to add some noise to a bifrost aero cache and I can't get it to give any result. I've punched the density way up and the noise just barely affects the volume. I really want to add noticable noise to this super smooth aero cache and I can't figure it out. In the example you gave here, what is the checker mapped into on the displacementShader1 node? Does this only work for a mesh and not bifrost aero cache? Any help would be much appreciated, thanks!
Message 5 of 8
lee_griggs
Did you convert the bifrost to polys?
Lee Griggs
AUTODESK
Message 6 of 8
omar_ahmed_vc
he asked that when u plugin a displacement map to the displacement node inside AiStandardVolume, it has no effect, but instead u must connect it to Displacement volume.
so I'm also asking why it doesnt work this way
Message 7 of 8
lee_griggs
Have you tried the example scene file here?
Lee Griggs
AUTODESK
Message 8 of 8
omar_ahmed_vc
sorry for late reply, the scene example works fine, but when I try to do the same technique manually it doesnt work, later on I found that the scene scale must be in cm not meters, and any scaling to the object must be freeze . so quite wierd , but it works in certain manner but not all the time.
