Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Using Noice
3 REPLIES 3
Parmenides
411 Views, 3 Replies
Using Noice
Trying to use Noice to de-noise. Regardless of the settings, if I select 'Render Settings/AOVs/Output Denoising AOVs', my image is blown out/overexposed.
Using Arnold 4.2.4 with Maya 2022.2 on Mac OS 11.6.
I was following a YouTube video and it suggests under file output to select Preserve Layer Name and Merge AOVs and under AOVs to use N, P, Albedo. But regardless of whatever I try, I always get a very overexposed image. Turning off 'Output Denoising AOVs' brings it back to normal renders.
I must be missing a major setting somewhere. Any suggestions? Thanks.
Tags (2)
Labels (2)
3 REPLIES 3
Stephen.Blair
in reply to: Parmenides
Output Denoising AOVs just adds some AOVs, it doesn't do anything to color management.
Where are you viewing this image? In the Arnold Render View?
// Stephen Blair
// Arnold Renderer Support
Parmenides
First I use Render View which shows the overexposed image. I save it as .exr and then I use the Utility/Arnold Denoiser but get a blank file.
Parmenides
Nevermind. I see that the images have to be saved via batch render for some reason. Render View doesn't give a meaningful image. Thanks.
