Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Using maya + arnold 4.2.13.4 Rendering a shader with opacity in AOV pass. Opacity is not computed at all. Same shader in beauty pass works perfectly. What's the problem?
9 REPLIES 9
Message 1 of 10
Riccardo_Zanettini
1411 Views, 9 Replies
Not sure what's wrong but this looks like and Arnold bug. Opacity is not there at all...
Tags (3)
Labels (3)
9 REPLIES 9
Message 2 of 10
more details
opaque uncheked
texture works fine (otherwise beauty won't be working)
Message 3 of 10
not a lot of people helping out in this forum
Message 4 of 10
Hard to tell exactly from that brief problem description, but I think you need to use an ai write color node, and enable Blend
// Stephen Blair
// Arnold Renderer Support
Message 5 of 10
let me rephrase the problem
I have a shader with opacity that is driven by a texture.
If I render that shader in the beauty AOV the transparency is working.
If in the shading group node I plug the same shader in a custom AOV (let's say beauty2) the opacity texture of the shader is ignored and the alpha is solid.
I hope this helps!
Message 6 of 10
When you "plug the same shader in a custom AOV" are you using an ai write color node? Do you enable Blend?
// Stephen Blair
Message 7 of 10
no I am not using a write color node... not sure why I would have to use and ai write color node can you please elaborate?
Message 8 of 10
also does the ai write node need to be plugged into the shading node?
Message 9 of 10
shading group node that is
Message 10 of 10
what you suggested works really well... thank you! I am just puzzled about why this node is necessary, Arnold doesn't process any of the shaders piped into the shading group node other than the surface material?
