Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
usd file from MtoA is compatible with KtoA ?
3 REPLIES 3
378 Views, 3 Replies
usd file from MtoA is correctly rendered on Maya with correct material assign , correct parameters of shaders .  Is it equivalent to MtoA usd file with KATANA rendering ?
Tags (3)
Labels (3)
3 REPLIES 3
Stephen.Blair
It's the same USD procedural in both plugins, so if you use the Arnold USD procedural to load the USD file, then "yes"
// Stephen Blair
// Arnold Renderer Support
pal.mezei
I would like to add that it's also possible to use UsdIn/KatanaUsdPlugins to import the USD file directly to the scenegraph. In that case, shapes and materials will be rendered correctly if you are using the plugins shipped with KtoA.
There are limitations regarding lights, Arnold-specific attributes on shapes, etc. However, we are working on removing those.
JWRodegher
Hello everyone, is there any ETA regarding those shapes limitations? I´ve also encountered several issues with normals, bumps and displacement which don´t translate at all. Any insight about this that you guys could possibly share?
Thank you.
Technology Administrators
