Hi, im unable to key the hueshift attribute from colorcorrect node with a controller.
☻First i created a float attribute at my controller(i tried the same in integer too)
☻then i linked hueshift attribute from colorcorrect node with the float attribute which i created at my controller(tried both set driven key also through connection editor)
Now when even i change the value in my controller it reflects the same at the float field of hueshift attribute from colorcorrect node. But in render, it behaves like the value is 0.
Any idea how to fix this issue?
