Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
triplanars in combination with texture refrence objects causing nan/inf errors
9 REPLIES 9
Message 1 of 10
1025 Views, 9 Replies
Attempted to bake these triplanar nodes with render selection to texture and the nans actually baked into the maps(blue spots). They also dont occur in the same places every time. removing the reference object seems to get rid of them but the reference object is required to stop swimming?
Tags (3)
Labels (3)
9 REPLIES 9
Message 2 of 10
Stephen.Blair
triplanar does not work Pref, that's a known issue
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
Hey Stephen, thanks for the response. So when you say "pref", do you mean the coordinate space setting? So if this was set to object or world it would work with the texture reference object?
Message 4 of 10
Stephen.Blair
Pref is the reference position that MtoA gets from the texture reference object.
If you use object or world, then you're not using the texture reference object, and you should see texture swimming.
// Stephen Blair
Message 5 of 10
ok so then if pref doesn't work with the triplanar you can't use it for animating objects?
Message 6 of 10
Good day Arnold Answers,
I was wondering if you could shed more light on this topic.
Right now our Studio is running on MtoA 3.1.2.1 with Arnold Core 5.2.2.1.
How unstable it the aiTriplanar in Pref at render time?
How unstable it the aiTriplanar in Pref when baked and is there a workaround for the NAN/INF errors?
What version has a working aiTriplanar in Pref?
This implicates our Pipeline decisions and scheduling predictions.
Kind Regards
Malcolm van Aardt
Technical Supervisor | Triggerfish Animation Studios
Message 7 of 10
Stephen.Blair
triplanar doesn't work with Pref, so you can't expect correct results
If you can wait until Arnold 5.3 is released, there's a fix
// Stephen Blair
Message 8 of 10
Stephen.Blair
You can't use it for anything where you want to use pref to prevent swimming
// Stephen Blair
Message 9 of 10
@Stephen Blair,
Thanks for the response. When is the relese date or Arnold 5.3?
Will it be a smooth transision /upgrade from 5.2.2.1 or will we need to rebuild our shaders?
Kind Regards
Malcolm van Aardt
Message 10 of 10
Stephen.Blair
3pm EST today
Arnold 5.3 is binary compatible for custom shaders. Custom operators would need to be recompiled.
// Stephen Blair
