Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
transparent material on maya with arnold render engine
3 REPLIES 3
pestle76
924 Views, 3 Replies
I need to fade out an object animating his opacity. But when the object is semi transparent I want to see only the back objects and not is internal or back faces.
There is a way?
Thanks.
Tags (1)
Labels (1)
3 REPLIES 3
lee_griggs
in reply to: pestle76
I am trying to imagine what you are getting vs what you want? Can you upload some images or a simplified scene of what you are getting?
I am thinking thin_walled, single-sided geo, ray_switch shader...?
Lee Griggs
Arnold rendering specialist
AUTODESK
pestle76
Sorry for the few details.
For example I have a scene with some object with an aiStandarsSurfaceMaterial. A cylinder and a cube (with some additional faces) must disappear animating the opacity from 100 to 0. 7097-a.jpgFor the transparency I change the Geometry>Opacity of the material property.
In this way when the cube is semi transparent I see your interior faces.
But I want to see only the frontmost faces and the back objects:
lee_griggs
Probably a cheat, but could you switch it with a regular cube (keyframe visibility on/off) and change the opacity of that one?
Lee Griggs
AUTODESK
