Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Transmission is behaving oddly
7 REPLIES 7
Message 1 of 8
455 Views, 7 Replies
When I render a sequence, the look of the transmission on an object changes randomly depending on the frame. I've rendered more than once and the change happens on different frames. Any idea what would cause this?
Look 1
Look 2
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
Stephen.Blair
What is changing between frames? I don't mean the transmission, but is the lighting changing? Are things moving? Or is it a static scene, no animation?
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
in reply to: Stephen.Blair
The camera is slowly pushing in, otherwise nothing is changing in the scene. Did the image links work? I'm not able to click on them..
Here are urls just in case-
https://ibb.co/QmbrPKM
https://ibb.co/g90WWhL
Message 4 of 8
Also just did a test without a camera move, same issue..
Message 5 of 8
Sorry just updating with some troubleshooting I've been doing. I put the shader on a plane to see if it might be an issue with the geo, and it did the same thing.
Message 6 of 8
Stephen.Blair
@Michael Sime Please upload a simple scene that shows the problem.
// Stephen Blair
Message 7 of 8
Ok so I found the issue, just not sure why it caused it. I had an image map for the transmission weight, once I removed that connection and used a flat number it rendered correctly. I'll have to handle the weight in post. But thank you so much for your help, even offering to look at the scene file. I really appreciate it.
Message 8 of 8
Stephen.Blair
Maybe we were reading different mipmap resolutions on different frames...
An Info-level Arnold log would show what mipmap levels were being used.
// Stephen Blair
Technology Administrators
