Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
template file not working for osl shader UI
28 REPLIES 28
Message 1 of 29
1709 Views, 28 Replies
hey guys, I'm making an UI for my osl shader and everything compiles fine if I put just one control to the template file. but as soon as I put another control, the template file is no longer compiled by maya...don't know why........
this is the link to the doc.: https://docs.arnoldrenderer.com/display/A5AFMUG/Creating+a+Shader
it works fine for just one parameter.....asa I do self.addControl(bla bla bla) on another line it doesn't work
Tags (2)
Labels (2)
28 REPLIES 28
Message 21 of 29
do you know how can i compile all these files(template, mtd and osl) without restarting maya?
cause right now I'm into a recursive process of restarting maya...xd
Message 22 of 29
no way, you have to restart Maya each time you change the code
Message 23 of 29
If maya.classification STRING "shader/surface" you get automatically normalCamera & hardwareColor.
So you have to use self.suppress!
Message 24 of 29
ahhhh! got it....thanks for that
Message 25 of 29
Johanalv
Hey, is it possible to share how you got the checkbox working with osl/template file? Can't seem to find the way. Thanks
Message 26 of 29
rachid_1
in reply to: Johanalv
Hi
You have to change "string widget" to "boolean" in your osl shader
like this:
string widget = "boolean",
Message 27 of 29
Johanalv
in reply to: rachid_1
Thanks! That actually works. btw, do you if it's possible to add a drop down menu as a widget? Like this:
Currently I have:
string widget = "popup" and just shows a text input where I have to manually input the text.
Message 28 of 29
rachid_1
I asked the same question almost 4 years ago, but no answer! any way in Houdini you do that in .mtd file by adding this lines:
houdini.type STRING "menu:replace:menu"
houdini.menu STRING "Normal;Normal;Average;Average;Darken;Darken;Multiply;Multiply;Color Burn;Color Burn;Linear Burn;Linear Burn;Lighten;Lighten;Screen;Screen;Color Dodge;Color Dodge;Linear Dodge;Linear Dodge;Spotlight;Spotlight;Spotlight Blend;Spotlight Blend;Overlay;Overlay;Hard Light;Hard Light;Soft Light;Soft Light;Pin Light;Pin Light;Hard Mix;Hard Mix;Difference;Difference;Exclusion;Exclusion;Subtract;Subtract;Divide;Divide;Hue;Hue;Saturation;Saturation;Color;Color;Value;Value "
What you can do in Maya is add "annotation", in aeTemplate, that way you have a popup showing a list, but you have to enable:
"display ToolClips" in Maya Preference/Help/Popup Help
some things like this:
annotation="Normal, Average, Darken, ...")
Message 29 of 29
Johanalv
Thanks a lot, guess that's currently a limitation of Arnold's osl implementation.
Technology Administrators
