Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Render to texture - region resolution?
2 REPLIES 2
johan8CZ8M
555 Views, 2 Replies
Hello
Using "arnoldRenderToTexture" in a batch session under Linux (Mtoa 2.0.2.2)
If I pass in 512 to arnoldRenderToTexture my render comes out at 360x280.
Looking in the render log I see this:
rendering image at 512 x 512 (360 x 280 region), 3 AA samples
Any ideas what might be going on?
It's a simple pCube1 + env light scene.
Thank you
Tags (1)
Labels (1)
2 REPLIES 2
Stephen.Blair
in reply to: johan8CZ8M
Is 360 x 280 the Image Size in the Render Settings?
I don't repro when I run the command interactively (and I don't see that "rendering image" log)
// Stephen Blair
// Arnold Renderer Support
johan8CZ8M
Tested under Linux? For Windows it works fine here.
The log is from terminal - not the script editor
A wise colleague showed me the following workaround:
arnold_globals = pymel.core.PyNode("defaultArnoldRenderOptions")
arnold_globals.aiUserOptions.set("texture_per_file_stats false region_min_x 0 region_max_x 511 region_min_y 0 region_max_y 511")
