Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Render sequence crash
16 REPLIES 16
Message 1 of 17
skeydzh
354 Views, 16 Replies
Hey there! I'm trying to render a sequence on my project but everytime it gives me crash. I tried to rebuild the same project by copying things one by one to a new project but at some point it breaks again too. What can I do? I use Maya 2023.2 and also tried to use 2022 and 2024, but same problem.
16 REPLIES 16
Message 2 of 17
thiago.ize
in reply to: skeydzh
What version of mtoa are you using? Have you tried with the latest version in case it's an already fixed bug? If it fails after a certain point of adding things, that suggests something you are adding is causing a problem: try to identify what that is.
Message 3 of 17
skeydzh
in reply to: thiago.ize
I tried use the latest version of Arnold too, didn't help. I thought it was arnold standin object first, but I deleted it and still doesn't work. I can assume this happens probably after saving a project?
Message 4 of 17
lee_griggs
What else is in the scene? Can you Win+Shift+S it and post it here?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 5 of 17
skeydzh
in reply to: lee_griggs
that's the scene
Message 6 of 17
lee_griggs
I would hide half of the scene. See if the problem persists, then hide half of the remaining scene and keep going until you identify what is causing it to fail.
Lee Griggs
AUTODESK
Message 7 of 17
skeydzh
Just hide? Or better to delete from scene at all?
Message 8 of 17
lee_griggs
Hiding it should be fine.
Lee Griggs
AUTODESK
Message 9 of 17
skeydzh
I tried to hide first and second half of the scene and still I'm getting crash. Then I tried to hide everything and the problem is still there
Message 10 of 17
Stephen.Blair
  • Do you have an Arnold log (verbosity level Info) for a frame that crashes?
  • How many frames before the crash?
  • Test with a batch render. Still crash?
  • Scene crashes even though you've hidden everything? Can we see an Arnold log for that? And maybe export that empty scene to an ass file, and post that.
// Stephen Blair
// Arnold Renderer Support
Message 11 of 17
skeydzh
in reply to: Stephen.Blair
Where can I get arnold log crash? Because it just crashes me maya and gives only maya log
Message 12 of 17
Stephen.Blair
In the Arnold Render Settings. There's a Diagnostics tab, where you can set the verbosity, and enable file logging.
// Stephen Blair
Message 13 of 17
skeydzh
Got it! But after the crash arnold doesn't create a log. What should I do?
Message 14 of 17
lee_griggs
Where are you saving it to?
Lee Griggs
AUTODESK
Message 15 of 17
skeydzh
I save it to SSD disk
Message 16 of 17
skeydzh
Also Render batch is working too
Message 17 of 17
angeldak0ta91
Did you fix this?
