Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Refraction not showing any colour - Maya
4 REPLIES 4
535 Views, 4 Replies
Following along to Lee Griggs tutorial and almost there, but for some reason the refraction is grey. Do you have any advice for fixing this?
Labels (3)
4 REPLIES 4
@LeeGriggs
teddude75
Are you using a Al Shader? What version are of Arnold are you using? Al Shader might not be compatible.
in reply to: teddude75
I am using an aiStandardSurface and the latest version of Arnold.
lee_griggs
It looks like you are missing this step from the tutorial (see shader at bottom of tutorial):
  • Connect the same projected texture to the Specular IOR and Transmission Color via a Rangeshader. The Range shader is used to define how much the texture will refract and can be used to fine-tune the effect.
Lee Griggs
Arnold rendering specialist
AUTODESK
Technology Administrators
