Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
object casting shadows but not blocking skydome specular reflections
8 REPLIES 8
Message 1 of 9
jakob.littlewater
786 Views, 8 Replies
Hi there,
I can't wrap my head around this. Is there any way to disable specular reflections without disabling cast shadows? I need an object to cast shadows, but be invisible to everything else. But the object always 'blocks' the specular reflections of my HDRi skydome light unless I disable cast shadows.... Even with a rayswitch shader won't help me there, same behavior... Any ideas?
Thank you!
Best Regards,
Jakob
Tags (1)
Labels (1)
8 REPLIES 8
Message 2 of 9
If I understand correctly, it works for me. I can disable specular reflections on the sphere, and still have its shadow.
I set the skydome to have red shadows
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
Thank you for your quick response, Stephen! Sorry for being unclear. I meant an object stands in front of a mirror, and casts a drop shadow on a ground plane. And now I want to disable spec refl. The object appears black in the mirror, cuts out the reflection of the dome, and disappears only completely when I disable casts shadows.
Message 4 of 9
Ok, now I remember...
What you're seeing is because of the skydome light, which is sampled with shadow rays.
I don't remember the exact explanation, but when an object casts shadows from the skydome light, you also get the specular
I had a another case about this. We used shadow linking to get rid of the shadows (instead of disabling Cast Shadows). So we disabled shadows for just the skydome, and left shadows from all other lights.
// Stephen Blair
Message 5 of 9
Would you be able to upload some images (win+shift+s)?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 6 of 9
Message 7 of 9
You can create 2 skydomes.
1st - with all but spec
2nd - spec only and Cast Shadows off.
Sphere is light linked only to Skydome1 (no spec)
Mirror is light linked only to Skydome2 (spec only)
Message 8 of 9
in reply to: brian_Foley
Hey Brian, thanks for your answer. I already tried that. But as you see in the screens, then the reflection of other objects in the mirro get weirdly semi-transparent... mirror-half-transp.jpg
Message 9 of 9
brian_Foley
Did you at some point turn off 'receive shadows' in the Render Stats of the Mirror Shape?
