Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Noice command line for EXR sequence on Mac
7 REPLIES 7
Message 1 of 8
tsines
348 Views, 7 Replies
I am trying to do a demo for my students at Pratt to run Noice for Denoising their image sequences for their senior projects. Unfortunately the students have to use "Render Sequence" instead of command line batch rendering because Autodesk has not licensed standalone Arnold for the school, which results in watermarks.
So to circumvent this, they are rendering with the Arnold default settings, with some AOV modifications; exporting the following AOVs: RGBA, Depth, N_Noice, Albedo, Coat, Coat_Albedo, Coat_Direct, Coat_Indirect, Denoise_Albeco_Noice, Diffuse, Diffuse_Albedo, Diffuse_Direct, Diffuse_Indirect, Motionvector, Shadow, Shadow_Mask, Shadow_Diff, Shadow_Matte, Specular, Specular_Albedo, Specular_Direct, Specular_Indirect, SSS, SSS_Albedo, SSS_Indirect, SSS_Direct.
Scene_layerContactSheetScene_layerContactSheet
We would ideally like an exact denoised clone of the original .exr, but when doing it standalone (one frame at a time) I had to add the -l AOV-flags for each AOV, which is beyond tedious. Additionally, noice gives the following errors:
% /Applications/Autodesk/Arnold/mtoa/2022/bin/noice -i /Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest/ShadowTest.0001.exr -o /Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest_DN/ShadowTestDN.0001.exr -pr 4 -l specular -l motionvector -l z -l sss -l sss_direct -l sss_indirect
noice 7.1.1.0 [eba1345a] - the Arnold denoiser
Loading images...
Loading file "/Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest/ShadowTest.0001.exr".
Using feature AOV 'denoise_albedo' with filter 'gaussian_filter'
Using feature AOV 'N' with filter 'gaussian_filter'
Using feature AOV 'Z' with filter 'gaussian_filter'
Working with 1 frame at 1920x1080
Will denoise AOV "RGBA", using associated variance
   Output file will be "/Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest_DN/ShadowTestDN.0001.exr"
Will just copy AOV "motionvector", variance not found
Will just copy AOV "specular", variance not found
Will just copy AOV "sss", variance not found
Will just copy AOV "sss_direct", variance not found
Will just copy AOV "sss_indirect", variance not found
   Could not find AOV with source z
Could not find AOV "z" to denoise, skipping.
Start denoising (patch radius 4, search radius 9, variance 0.5)
Denoising RGBA
Denoising motionvector
   Could not find AOV with source motionvector and filter variance_filter
   Could not find variance for AOV "motionvector", skipping denoise.
Denoising specular
   Could not find AOV with source specular and filter variance_filter
   Could not find variance for AOV "specular", skipping denoise.
Denoising sss
   Could not find AOV with source sss and filter variance_filter
   Could not find variance for AOV "sss", skipping denoise.
Denoising sss_direct
   Could not find AOV with source sss_direct and filter variance_filter
   Could not find variance for AOV "sss_direct", skipping denoise.
Denoising sss_indirect
   Could not find AOV with source sss_indirect and filter variance_filter
   Could not find variance for AOV "sss_indirect", skipping denoise.
Finished denoising
Saving image /Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest_DN/ShadowTestDN.0001.exr (1920 x 1080 x 19)
I set all of my filters to variance, except for RGBA, N, Z, and denoise_albedo, and they still are ignored by Noice.
As for using Noice on a sequence, I am really striking out. I read these threads:
https://forums.autodesk.com/t5/maxtoa-forum/denoice-exe-animation-batch-script-v0-1-for-3ds-max-down...
https://forums.autodesk.com/t5/arnold-forum/noice-won-t-process-full-sequence/m-p/11040670
https://forums.autodesk.com/t5/mtoa-forum/how-to-denoise-image-sequence-through-noice-standalone-in-...
Theoretically the process in Linux should be the same, or similar, for Mac.
So I tried modifying the script mentioned here
https://github.com/zpelgrims/noice_command_generation/blob/master/noice_command_generation.py
in a text editor and keep getting SyntaxErrors no matter what I do:
import re
# only change these variables
filename_input = "/Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest/ShadowTest.####.exr"
filename_output = "/Volumes/RAID4TB_02/TreeGrowth/images/ShadowTest_DN/ShadowTestDN.####.exr"
arnold_bin_path = "/Applications/Autodesk/Arnold/mtoa/2022/bin"
startframe = 1
endframe = 40
variance = 0.5
pixel_search_radius = 9
pixel_neighborhood_patch_radius = 3
temporal_range = 6
light_aov_names = ["frontlight", "backlight"] # if no light aov denoising needed, just leave list empty: []
filename_input_sequence_number = re.sub(r'#+',lambda m: r'{{:0{}d}}'.format(len(m.group(0))), filename_input)
filename_output_sequence_number = re.sub(r'#+',lambda m: r'{{:0{}d}}'.format(len(m.group(0))), filename_output)
for i in range (startframe, endframe + 1):
temporal_range_string = ""
light_aov_string = ""
for j in range(-temporal_range/2, temporal_range/2):
if (j==0) or (i+j < startframe) or (i+j > endframe):
continue
temporal_range_string += "-i " + filename_input_sequence_number.format(i+j) + " "
for k in light_aov_names:
light_aov_string += "-aov " + str(k) + " "
print (arnold_bin_path + "/noice"
+ "-patchradius " + str(pixel_neighborhood_patch_radius) + " " \
+ "-searchradius " + str(pixel_search_radius) + " " \
+ "-variance " + str(variance) + " " \
+ light_aov_string + " " \
+ "-i " + filename_input_sequence_number.format(i) + " " \
+ temporal_range_string + " " \
+ "-output " + filename_output_sequence_number.format(i))
if i is not endframe:
print " &&",
I tried to put the print (arnold_bin_path on one which resulted in the following error:
SyntaxError: Missing parentheses in call to 'print'. Did you mean print(" &&", end=" ")?
(base) sines@scaleMP ~ % python noice_command_generation.py
Traceback (most recent call last):
  File "noice_command_generation.py", line 23, in <module>
TypeError: 'float' object cannot be interpreted as an integer
At this point I'm not sure what to modify next as I am a full-on Python noob and can't find a solution with just randomly adding parentheses.
Curious as to how do I use the Denoise imager flags for a Mac without Optix? It's a shame I have 16GB of GPUs doing absolutely nothing right now. We tried Denoising in Nuke and it looks like pastel garbage; so Noice is our only choice to denoise.
Hoping to solve this soon. Thanks in advance for your help!
Labels (3)
7 REPLIES 7
Message 2 of 8
Stephen.Blair
in reply to: tsines
So you set up all the AOVs with two drivers, as shown here ?
https://arnoldsupport.com/2021/03/22/mtoa-denoising-aovs-with-the-arnold-denoiser/
These messages say that there's no variance AOV for specular:
Denoising specular
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
tsines
in reply to: Stephen.Blair
@Stephen.Blair no, I wasn't aware it took 2 drivers per AOV. I will reconfigure and try again. Thank you.
Any ideas on a Python script to run Noice on all of the merged AOVs on all of the EXRs in an image sequence? Processing 1 EXR at a time is pretty tiresome.
Message 4 of 8
Stephen.Blair
in reply to: tsines
If you wanted that Python you posted to work, do this:
    test = arnold_bin_path + "/noice.exe " \
            + "-output " + filename_output_sequence_number.format(i),
    print( test )
// Stephen Blair
Message 5 of 8
tsines
in reply to: tsines
This is my revised script [got rid of all of the \ so that it would be read on one line]
Reminding you that I am on a Mac, so I have removed "/noice.exe" and replaced it with "/noice"
import re
startframe = 1
endframe = 40
variance = 0.5
temporal_range = 6
continue
test = arnold_bin_path + "/noice" + "-patchradius " + str(pixel_neighborhood_patch_radius) + " " + "-searchradius " + str(pixel_search_radius) + " " + "-variance " + str(variance) + " " + light_aov_string + " " + "-i " + filename_input_sequence_number.format(i) + " " + temporal_range_string + " " + "-output " + filename_output_sequence_number.format(i),
print( test )
Getting the following.
(base) sines@scaleMP ~ % python3 /Users/sines/noice_command_generation.py
  File "/Users/sines/noice_command_generation.py", line 32
    test = arnold_bin_path + "/noice" \
IndentationError: unindent does not match any outer indentation level
Message 6 of 8
I've reformatted your script to make it more readable on here, I think you had a trailing '\' at the end that was causing the unindentation error
import re
startframe = 1
endframe = 40
variance = 0.5
temporal_range = 6
    for j in range(int(-temporal_range/2), int(temporal_range/2)):
            continue
    test += " -patchradius " + str(pixel_neighborhood_patch_radius)
    test += " -searchradius " + str(pixel_search_radius)
    test += " -variance " + str(variance) + " " + light_aov_string
    test += " -i " + filename_input_sequence_number.format(i)
    test += " " + temporal_range_string
    test += "-output " + filename_output_sequence_number.format(i)
    print( test, )
      print(" &&",)
Ashley Handscomb Retallack
Senior Software Engineer (Arnold)
Arnold Documentation | Arnold Downloads
Message 7 of 8
tsines
in reply to: tsines
@ashley.handscomb.retallack I tried the above, and all it doesn't give me an error, but instead, its print every frame's theoretical output, but doesn't actually start Noice. I imagine that is bevause of the word "test" but I want to actually pull the trigger and process my frame sequence.
Since I have a ton of merged AOVs (diffuse, motionvector, shadow_matte, sss, specular, *_indirects, and so on) to process per frame, how would I automatically run Noice on these frames without having to list each and every AOV? And where would I list them? Typically noice looks for this string:
The example python script includes -aov frontlight and -aov backlight, whereas I am only using aiSkydome.
Message 8 of 8
@tsines The script only prints out the commands to be run in the command line, you could instead have it run through subprocess.call
As it is only an example, to use the lights you expect you should edit the light_aov_names list to have the names of your light groups
I'll see if I can change the script for you to call the noice command instead of just printing it out
Technology Administrators
