Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Multiple Node Selection - aiSetParameter custom node
0 REPLIES 0
Message 1 of 1
f.fiordalice
324 Views, 0 Replies
Hi everyone,
I'm currently in Maya, trying to create my custom node inside MtoA so I can deal with internal Arnold's nodes.
I have a very simple node network in my maya session, it is basically 2 nodes, one is a aiMaterialX node and the other one is ai StandIn Arnold node. The first one is the one that describe a more complex shader that coming from another scene with a more complex node network (a shader basically).
So now, what I would like to do is replicate the aiSetParameter behaviour but with some sort of multiple selection, for instance:
I've got two nodes inside the materialX like a aiColorCorrect and a aiImage and I would change the aiColorCorrect.multiply and aiImage.offset without creating two aiSetParameter.
Ideally the node I would create will send those two parameters to the materialX node operator just plug-in my custom node/operator to it.
Any idea about how to set this kind of things?
I already have some knowledges about how to create a translator for MtoA/Arnold and I was trying, in a first attempt, to get the same thing of a aiSetParameter just setting (hardcoding) some attributes in this way:
void MyCustomNode::Export(AtNode* node)
    // Selection
    AiNodeSetStr(node, "selection", "/NG_beauty_skin/aiColorCorrect5");
    // Assignments
    AtArray *assignmentsArray = AiArrayAllocate(2, 1, AI_TYPE_STRING);
    AiArraySetStr(assignmentsArray, 0, "/NG_beauty_skin/aiColorCorrect5 float gamma=8.0");
    AiArraySetStr(assignmentsArray, 1, "/NG_beauty_skin/aiColorCorrect5 rgb add=[0.0 0.3 1.0]");
    AiNodeSetArray(node, "assignment", assignmentsArray);
but I just encounter a problem after this, and basically I cannot able to get the same array in the selection part of the code.
Any thoughts?
Thank you so much in advance.
Fabio
Tags (3)
Labels (3)
0 REPLIES 0
Technology Administrators
