Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
mask from hidden object
3 REPLIES 3
91 Views, 3 Replies
I have the following problem to solve. An object is inside another object. Additionally, it is invisible. It is possible to render a mask from such an object.
3 REPLIES 3
Christoph_Schaedl
in reply to: 891198
I fear you need a second render with only the object.
You could set it up with Rendersetup.
https://linktr.ee/cg_oglu
in reply to: 891198
I know this method, layers. I was wondering if there was a way to release it as an additional mask. Without using layers.
But overall, it's also a good method.
lee_griggs
in reply to: 891198
I thought there might be a workaround too but, unfortunately, it won't work if the outside object is opaque.
Lee Griggs
Arnold rendering specialist
AUTODESK
