Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
maketx --colorconfig not converting correctly
2 REPLIES 2
dave-c
1008 Views, 2 Replies
Hello
I am trying to use maketx in the command line (Linux) to batch create my .tx files.
I am using an .ocio file within Maya and when I generate .tx from within Maya results are correct.
Using the --colorconfig flag with maketx (or oiiotool) is not working for me though. Disregarding other flags should my command just be:
maketx --colorconfig /path.../config.ocio /path.../file.jpg
The OCIO environment variable is not set system wide, but if I have the full path to it, that should be enough?
Also I have tried to unpick the command Maya uses when creating .tx from there and it uses
maketx /path.../file.jpg --colorconvert "Utility - sRGB - Texture" acescg
When I do that from the command line I get an error 'Creating Color Processor' even after I set the OCIO variable within the shell.
Any thoughts anyone?
Dave
Tags (1)
Labels (1)
2 REPLIES 2
Stephen.Blair
in reply to: dave-c
If I take the command that Maya used, and add --colorconfig, that works for me.
C:\Users\blairs>%A%\bin\maketx C:\Users\blairs\Documents\maya\projects\default\sourceimages\test\test.1005.jpg --opaque-detect --constant-color-detect --monochrome-detect --fixnan box3 --oiio --attrib tiff:half 1 -v --unpremult --oiio -u --colorconvert sRGB ACEScg --format exr -d half --compression dwaa"
WARNING: node "color_manager_syncolor" is already installed
  prep                      0.03s   (123.0 MB)
Reading file: C:\Users\blairs\Documents\maya\projects\default\sourceimages\test\test.1005.jpg
  read "C:\Users\blairs\Documents\maya\projects\default\sourceimages\test\test.1005.jpg" 0.64s   (173.4 MB)
  misc2                     0.00s   (173.4 MB)
  pixelstats                0.53s   (173.4 MB)
  misc2b                    0.00s   (173.4 MB)
  Converting from colorspace sRGB to colorspace ACEScg
make_texture ERROR: Error Creating Color Processor: Arnold Color Managers can only convert from and to working linear color space, getProcessor
C:\Users\blairs>%A%\bin\maketx C:\Users\blairs\Documents\maya\projects\default\sourceimages\test\test.1005.jpg --opaque-detect --constant-color-detect --monochrome-detect --fixnan box3 --oiio --attrib tiff:half 1 -v --unpremult --oiio -u --colorconfig C:\solidangle\arnold\Arnold-7.0.0.0-windows\ocio\configs\arnold\config.ocio --colorconvert sRGB ACEScg --format exr -d half --compression dwaa"
using config file C:\solidangle\arnold\Arnold-7.0.0.0-windows\ocio\configs\arnold\config.ocio
  prep                      0.02s   (123.4 MB)
  read "C:\Users\blairs\Documents\maya\projects\default\sourceimages\test\test.1005.jpg" 0.53s   (173.7 MB)
  misc2                     0.00s   (173.7 MB)
  pixelstats                0.49s   (173.7 MB)
  misc2b                    0.00s   (173.7 MB)
  Unpremulting image...
  color convert             1.55s   (375.2 MB)
  misc3                     0.01s   (324.9 MB)
  resize & data convert     0.00s   (324.9 MB)
  SHA-1: 80F49171C7827D985CE86342430987F4B8C49D75
  SHA-1 hash                0.52s   (324.9 MB)
  AverageColor: 0.373445,0.378766,0.369441
  misc4                     0.00s   (324.9 MB)
maketx run time (seconds):  3.12
  file read:        0.53
  file write:       0.00
  initial resize:   0.00
  hash:             0.52
  pixelstats:       0.49
  mip computation:  0.00
  color convert:    1.55
  unaccounted:      2.07  ( 0.02  0.00  0.00  0.01  0.00)
maketx peak memory used: 375.2 MB
// Stephen Blair
// Arnold Renderer Support
dave-c
in reply to: dave-c
Hi Stephen
I see...so --colorconfig and --colorconvert need to be used together.
Thanks for looking at this.
Technology Administrators
