Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
LookdevX Arnold image node relative path issue
3 REPLIES 3
LFGFX3D
249 Views, 3 Replies
Hi All. I have the latest versions of arnold, Maya and USD plugin. I noticed that by default, lookdevX sets relative file path on the arnold image file node. When rendering, it gives me an error (cannot resolve file) even though the path is correct relative to the usd file. When I manually change the path to absolute, it works. I also tried regular AtoM (non lookdevX/usd) node and it works with both relative and absolute paths. The lookdevX materialX nd_image node works fine too. So it seems like there's some issue with the lookdevX arnold image node specifically. Any suggestions?
3 REPLIES 3
sathya.rajan
in reply to: LFGFX3D
Hi @LFGFX3D
Thanks for reporting this. This is a known issue logged as MTOA-1509 and the fix should be available in the upcoming updates, sorry for the inconvenience in the meantime.
Sathya Rajan
QA
LFGFX3D
in reply to: sathya.rajan
Thanks!
LFGFX3D
Still no fix in 5.3.5.3 😞
