Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
layeredTexture1: could not set BOOL parameter "enable0". How to fix?
5 REPLIES 5
artofcharly
2489 Views, 5 Replies
Hi. dear support. When I start render, I saw this warning? Why? And how to fix this?
Thank you and have a great day.
Best regards,
Andrew.
Tags (3)
Labels (3)
5 REPLIES 5
in reply to: artofcharly
Is this your own layer shader or Arnold's layer shader?
artofcharly
Hi, @Bhuwan Sharma
No this is standard layeredTexture node with 2 Inputs
I just mix texture sss and simple color.
Thank you.
Best regards,
Andrew.
well , that's just a warning ...the data types conversion between mtoa might be causing this to appear........don't have exact solution though....
better use arnold's layerRGB....this one is better ..
artofcharly
Ok. Thank you very much for this answer.
Technology Administrators
