Is there a way to use specular anisotropy without it relying on UV's?
Is there a way to use specular anisotropy without it relying on UV's? currently running into the issue where the spec stops on the UV seam
lee_griggs
Does increasing Subdivision Iterations or Texture Filtering help?
Lee Griggs
Arnold rendering specialist
AUTODESK
thanks for the suggestion. I tried this and no luck unfortunately
T0M0X
I think that one of the solution is to connect aiUtility (Shade Mode - flat, Color Mode - Normal, Overlay Mode - none) to tangent of aiStandardSurface
