Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Hypershade icons contain large 'A'
6 REPLIES 6
maja.divjakW2VMQ
2993 Views, 6 Replies
Finally managed to download Maya 2017 educational version and Arnold 2018 and am now able to batch render without a watermark. Yay. The hypershade is looking a little unusual however. The icons have a large 'A' for Arnold and don't show the material, as per the attached image. Is this normal or is there a problem?
Thank so much!
Tags (2)
Labels (2)
6 REPLIES 6
yes the render swatches have been disabled by default as they can cause several issues, slowdowns, etc... if you want to enable them, you need to go in the render settings, tab "System", and activate "Enable Swatch Render". This will bring back the little shaded spheres.
Thank you, most helpful!
not working in maya 2022 and last arnold version. everything is enabled.
bhoyle
in reply to: maja.divjakW2VMQ
@Stanislav Onishenko
Same situation here: Swatch Rendering in Settings -> Display is ON, Swatch Rendering in Rendersettings -> System is ON, Hypershade PAUSE Swatchupdates are ON
Maya 2020 with latest Arnold Version 4.2.4
Very annoying to navigate the hypershade when everything looks the same.
This is a known issue: swatches do not render even when Swatch Render is enabled.
// Stephen Blair
// Arnold Renderer Support
This is still an issue? Seems to be.
