how to load the vdb
excentriPMNA2
how to load the vdb
excentriPMNA2
I made the vdb sequence in the houdini.
The file name is flame.001.vdb, flame.002.vdb, flame.003.vdb, etc.
in Maya, i made arnold's volume node.
in attribute editor in the volume node, i specified the flame.001.vdb in the Filename attribute .
but any sequence didn't load.
Stephen.Blair
Put an =frame expression in the Frame attribute.
// Stephen Blair
// Arnold Renderer Support
Once you put the expression like Stephen Blair mentionned, you have to change the numerical padding from file.000.vdb to file.###.vdb
heat and fuel Grids make the BBOX disappear from Maya viewport.
excentriPMNA2
thank you for your replies.
but, how do you make that heat and fuel Grids make the BBOX disappera from Maya viewport?
use Houdini to generate that kind of grids
excentriPMNA2
thank you very much
excentriPMNA2
another question?
in the volume node, the difference between Padding and Volume Padding?
