Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to define outAlpha connection in materialx
4 REPLIES 4
500 Views, 4 Replies
nodes that are defined with output color3 could have an alpha output in maya, e.g MayaFile, how to define outAlpha connection in materialx?
Tags (1)
Labels (1)
4 REPLIES 4
Stephen.Blair
MtoA does not send a MayaFile node to Arnold.
MayaFile is converted to an image node, possibly with other shader nodes (such as color_correction).
file.outAlpha becomes a connection to the "a" channel of the image node output
Your materialx document should use only Arnold nodes.
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
My bad, MayaFile is not a good example.
let's say, what if I connect the alpha output of AiImage to a float plug. It seems we can only have fixed type output of a specific node and the output of AiImage is color3, what to do if I use the alpha channel(in MaterialX).
Stephen.Blair
If you connect the alpha output of AiImage, then image.a is connected. For example:
standard_surface
 name aiStandardSurface1
 base aiImage1.a
 base_color aiImage1
 name aiImage1
 filename "noicon.pic"
 missing_texture_color 0 0 0 1
// Stephen Blair
Okay, I see. And then, is there any way to denote such kind connection in materialx? From what I know, output of AiImage could be color4, maybe I should put a rgba_to_float node in between?
