MtoA does not send a MayaFile node to Arnold.
MayaFile is converted to an image node, possibly with other shader nodes (such as color_correction).
file.outAlpha becomes a connection to the "a" channel of the image node output
Your materialx document should use only Arnold nodes.
My bad, MayaFile is not a good example.
let's say, what if I connect the alpha output of AiImage to a float plug. It seems we can only have fixed type output of a specific node and the output of AiImage is color3, what to do if I use the alpha channel(in MaterialX).
If you connect the alpha output of AiImage, then image.a is connected. For example:
standard_surface { name aiStandardSurface1 base aiImage1.a base_color aiImage1 } image { name aiImage1 filename "noicon.pic" missing_texture_color 0 0 0 1 }
Okay, I see. And then, is there any way to denote such kind connection in materialx? From what I know, output of AiImage could be color4, maybe I should put a rgba_to_float node in between?
