Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to apply alpha map in aiToon shader in Maya
2 REPLIES 2
1552 Views, 2 Replies
Hi guys! I have a cartoon character with aiToon shader on it. And I need to add alpha on eyelashes. Toon shader doesn't give correct transperency if I put alpha in transmission slot. Is there any way to add alpha map?
Labels (5)
2 REPLIES 2
You can plug your alpha map to Transmission Weight, and set Specular Weight to 1.
make sure that Opaque is turned off on your object.
I've followed those instructions: but it turns the entire mesh invisible instead of just the transparent Alpha part
Technology Administrators
