Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to achieve this towel fabric?
4 REPLIES 4
mydio
498 Views, 4 Replies
Hello all, im trying to achieve this texture but im not sure if I needto create via Xgen or thru bump maps/noise mpas through PBR. What do you think the best way to go about this is?
Tags (3)
Labels (3)
4 REPLIES 4
lee_griggs
in reply to: mydio
It depends on how close to the camera it is. Maybe you could get away with displacement or bump if it is far away, otherwise, XGen splines would be a good option. There are plenty of XGen tutorials out there for this sort of thing. Arnold with XGen tutorials here.
Lee Griggs
Arnold rendering specialist
AUTODESK
mydio
in reply to: mydio
Thanks for that. I achieved a somewhat okay result with bump, but not exactly what I wanted. As for xgen, im having trouble figuring out how to create custom control maps. Will check those tutorials out!
mydio
in reply to: mydio
I read through the documentation for xgen, however when I create the nCloth and apply the paint tool, it gives me an error.
I tried a fresh scene with a flat, untouched plain polygon and when i apply the texture map, it works.
It's only when I move/adust/nCloth the polygon, that it gives me the error. What am i doing wrong?
# Warning: Some surfaces have no file texture assigned to the current attribute. #
// Error: XGen: Runtime error while setting up paint tool (C:\Program Files\Autodesk\Maya2022\plug-ins\xgen\scripts\xgenm\ui\widgets\xgExpressionUI.py:971) //
joie
in reply to: mydio
Keep in mind that, when you use any kind of cloth simulation, the original mesh is converted, so the actual mesh you see is NOT the one you used to create the xGen hair. That may the cause of that error?
Technology Administrators
