Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
How to access to the defaultArnoldDriver attribute ?
8 REPLIES 8
Message 1 of 9
1727 Views, 8 Replies
8 REPLIES 8
Message 2 of 9
Stephen.Blair
What version of MtoA?
In MtoA 2.1.x, just click an active AOV (AOVs tab of the Render Settings)
In pre-2.1 versions, do this:
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
Thank you very much.
And inside, I read on your website if I enable Merge AOV's, I can have all AOV's on a file with layers.
When I try, I have one file, but no layers.
Message 4 of 9
Stephen.Blair
Do you have <RenderPass> in your Image file prefix?
// Stephen Blair
Message 5 of 9
brian_Foley
How are you viewing your AOV's? You may have a layered file but if you are viewing it in Photoshop or After Effects you will need to have a plugin-in like ProEXR or Exr-IO to view the layers.
Message 6 of 9
*No, I don't have RenderPass in my image file prefix
Message 7 of 9
And, I try to open in Photoshop, without this plugin
Maybe it's the reason, I'm going to see
Message 8 of 9
Thanks a lot, exr-io works fine
Message 9 of 9
And thaks Stephen, I will use also the image file prefix
Technology Administrators
