Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Height Texture from Substance Painter is stretched in Maya
12 REPLIES 12
Message 1 of 13
Fajota
517 Views, 12 Replies
Hi!
I made texture in Substance Painter, but when I imported it to Maya the height stretched horizontally. The files (Maya & Substance Painter) are attached. How can I fix it?
Look the print screens bellow:
1) Perfect in Substance Painter
2) Imported to Arnold Maya
3) Adjustments in Arnold (Subdivision & Displacement Attributes)
4) The problem of stretched height continue
Labels (2)
12 REPLIES 12
Message 2 of 13
lee_griggs
in reply to: Fajota
Does it help if you export the displacement maps at a higher bit depth? 16 or 32-bit (preferably exr)?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 13
Fajota
in reply to: lee_griggs
When the Height or Displacement file is .exr 32 bits, the stretching is worse
Message 4 of 13
lee_griggs
in reply to: Fajota
Freezing the geo seems to have fixed the displacement direction issue. Using an extreme displacement value got me this. Maybe it would look better with a 32-bit EXR.
Lee Griggs
AUTODESK
Message 5 of 13
Fajota
Hi @lee_griggs !
I froze the object, but didn't work. I exported .exr 32 bits for the height file. You can see the screenshot below. The files are attached
01) Froze object
2) Positive Displacement Attributes Height = 4.000
3) Positive Displacement Attributes Height = 4.000
4) Negative Displacement Attributes Height = -4.000
5) Negative Displacement Attributes Height = -4.000
Message 6 of 13
lee_griggs
in reply to: Fajota
What do you mean? I see no directional displacement in your screengrabs.
Here is the working scene file.
Lee Griggs
AUTODESK
Message 7 of 13
Fajota
Hi @lee_griggs !
In your previous post, you said: "Freezing the geo seems to have fixed the displacement direction issue."
I thought of Freeze Transformations (screenshot below). Do not this is?... I'm sorry but this is the first time that I have worked with Substance Painter in Maya. Could you explain to me where I need to change? Thank you so much for your help
 a
Message 8 of 13
lee_griggs
in reply to: Fajota
Yes, Freeze Transformations fixed the directional displacement for you, didn't it? Did you try my scene?
Lee Griggs
AUTODESK
Message 9 of 13
Fajota
Hi @lee_griggs ! Sorry about the late reply! I was working... So I used your file, but didn't work. The files are attached. I work with Maya 2023.3 and Arnold MtoA 5.3.4.1
The config for export from Substance Painter is bellow.
Message 10 of 13
lee_griggs
in reply to: Fajota
It works fine for me. What didn't work?
Lee Griggs
AUTODESK
Message 11 of 13
Fajota
Hi @lee_griggs!
I recorded it step-by-step. Please watch the video below and tell me what I'm doing wrong
Message 12 of 13
lee_griggs
in reply to: Fajota
These are the settings that I used. Not sure why you need to set the displacement so high, but it works.
Lee Griggs
AUTODESK
Message 13 of 13
Fajota
hi @lee_griggs
The .exr files didn't work, but the .png files worked fine.
Thank you for being so helpful!
Technology Administrators
