Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
First frame takes 4 to 10 hours to render, following frames 22 m.
14 REPLIES 14
Message 1 of 15
giandosopaolo
1213 Views, 14 Replies
Hi
I am trying to understand what is causing my scene to have inconstant render times.
When I render with the Arnold Render View the render times are always 22 minutes (approximately).
When I render with the batch render however, the render time starts regularly and then balloons to 4-10 hours after the first 5 minutes.
This happens only for the first frame of the sequence. Not frame 001, just the first frame of any batch render sequence (so even if I render fro frame 2 to 150, frame 002 will render slower).
The other frames seem to render at normal speed.
My scene is a close up of a body with a few arnold standins of xgen grooms, but other shots of the same model did not have this problem.
Here is the LOG for frame 01, at the very end you can see the render time exploding. Any suggestion?
C:\Users\Paolo Giandoso\Documents\maya>render -r arnold -s 11 -e 150 -rd D:\_Projects\Mydas\Maya\images\Faces -cam Mydas_Detail_CAM_Shape2 -im Mydas_Face_Mydas_003b_iRender -ai:lve 2 -preRender "setAttr -type \"string\" defaultArnoldRenderOptions.aiUserOptions \"region_min_x 1152 region_min_y 0 region_max_x 1920 region_max_y 1080\";" D:\_Projects\Mydas\Maya\scenes\Mydas_Rendering_turnaround_03_v10.mb
Starting "E:\_Programs\Autodesk\Maya2023\bin\mayabatch.exe"
This plugin does not support createPlatformOpenGLContext!
Initialized VP2.0 renderer {
Version : 2016.11.62.12. Feature Level 5.
Adapter : NVIDIA GeForce RTX 3090/PCIe/SSE2
Vendor ID: 4318. Device ID : 8708
Driver : C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispsi.inf_amd64_07723ef396d40f1e\nvoglv64.dll.dll:31.0.15.2698.
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max texture coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 24576 MB.
CPU Memory Limit : 62202.3 MB.
MultiDraw consolidation : enabled
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 3.0 CUDA 12.0.89.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info cl_khr_external_semaphore cl_khr_external_memory cl_khr_external_semaphore_win32 cl_khr_external_memory_win32
Selected matching OpenCL Platform: NVIDIA Corporation NVIDIA CUDA OpenCL 3.0 CUDA 12.0.89.
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
00:00:02 1388MB | log started Mon Nov 28 14:31:00 2022
00:00:02 1388MB | Arnold 7.1.3.2 [2a385cac] windows clang-10.0.1 oiio-2.4.1 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/09/12 08:50:17
00:00:02 1388MB | running on PaoloWorkStation, pid=55008
00:00:02 1388MB | 1 x Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz (4 cores, 8 logical) with 65476MB
00:00:02 1388MB | NVIDIA driver version 526.98 (Optix 60805)
00:00:02 1388MB | GPU 0: NVIDIA GeForce RTX 3090 @ 1740MHz (compute 8.6) with 24575MB (23099MB available) (NVLink:0)
00:00:02 1388MB | Windows 10 (version 10.0, build 19045)
00:00:02 1388MB | soft limit for open files changed from 512 to 2048
00:00:02 1388MB |
00:00:02 1388MB | [color_manager_ocio] default ocio.config found in E:\_Programs\Autodesk\Arnold\maya2023\bin\../ocio/configs/arnold/config.ocio
00:00:02 1388MB | loading plugins from C:/OSL_Shaders ...
00:00:02 1388MB | hda.osl: hda
00:00:02 1389MB | [metadata] loading metadata file: C:/OSL_Shaders\hda.mtd
00:00:02 1389MB | jiWindowBox_Arnold.osl: jiWindowBox_Arnold
00:00:02 1389MB | ParallaxOcclusionMapping_v001.osl: ParallaxOcclusionMapping_v001
00:00:02 1389MB | loaded 3 OSL shaders in 0:00.00
00:00:02 1389MB | loading plugins from E:\_Programs\Autodesk\Arnold\maya2023\bin\..\plugins ...
00:00:02 1389MB | alembic_proc.dll: alembic uses Arnold 7.1.3.2
00:00:02 1389MB | cryptomatte.dll: cryptomatte uses Arnold 7.1.3.2
00:00:02 1389MB | cryptomatte.dll: cryptomatte_filter uses Arnold 7.1.3.2
00:00:02 1389MB | cryptomatte.dll: cryptomatte_manifest_driver uses Arnold 7.1.3.2
00:00:02 1390MB | synColor_shaders.dll: color_manager_syncolor uses Arnold 7.1.3.2
00:00:02 1404MB | usd_proc.dll: usd uses Arnold 7.1.3.2
00:00:02 1404MB | loaded 6 plugins from 4 lib(s) in 0:00.08
00:00:02 1413MB WARNING | [mtoa] [jiWindowBox_Arnold.oso] [node jiWindowBox_Arnold] Assigning temporary node id 1138176 to associated Maya type name aiJiWindowBoxArnold.
00:00:02 1413MB WARNING | [mtoa] [ParallaxOcclusionMapping_v001.oso] [node ParallaxOcclusionMapping_v001] Assigning temporary node id 1138177 to associated Maya type name aiParallaxOcclusionMappingV001.
Begin attempted read of a shade fragment XML file.
Attempting to read fragment XML code from: aiRectangleAreaLight.xml
Errors loading XML:
Could not find file: aiRectangleAreaLight.xml
End attempted read of fragment XML.
qt.svg: Cannot open file ':/expression.svg', because: No such file or directory
pymel.core : INFO : Updating pymel with pre-loaded plugins: mayaHIK, invertShape, curveWarp, substanceworkflow, hairPhysicalShader, ATFPlugin, ikSpringSolver, retargeterNodes, sweep, lookdevKit, Type, Boss, stlTranslator, bifrostGraph, modelingToolkit, meshReorder, MayaMuscle, matrixNodes, bifmeshio, polyBoolean, shaderFXPlugin, objExport, bifrostshellnode, ufeSupport, mayaVnnPlugin, substancemaya, glslShader, svgFileTranslator, GamePipeline, tiffFloatReader, MASH, poseInterpolator, bifrostvisplugin, ik2Bsolver, xgenToolkit, AbcExport, VectorRender, gameFbxExporter, OpenEXRLoader, Unfold3D, mayaCharacterization, mtoa, rotateHelper, AbcImport, autoLoader, sceneAssembly, gpuCache, Substance, mayaUsdPlugin, OneClick, nearestPointOnMesh, renderSetup, ArubaTessellator, substancelink, quatNodes, fbxmaya
Failed to execute userSetup.py
Traceback (most recent call last):
File "E:\_Programs\Autodesk\Maya2023\Python\lib\site-packages\past\builtins\misc.py", line 87, in execfile
exec_(code, myglobals, mylocals)
File "E:/_Resources/MegascanLibrary/support/plugins/maya/6.9/MSLiveLink/userSetup.py", line 14, in <module>
pm.evalDeferred("initPlugin()")
File "E:\_Programs\Autodesk\Maya2023\Python\lib\site-packages\pymel\internal\pmcmds.py", line 217, in evalDeferred_wrapped
res = new_cmd(*new_args, **new_kwargs)
RuntimeError: NameError: file <maya console> line 1: name 'initPlugin' is not defined
Warning: line 1: Unrecognized node type for node 'MayaNodeEditorSavedTabsInfo'; preserving node information during this session.
Warning: line 1: Unrecognized node type for node 'hyperShadePrimaryNodeEditorSavedTabsInfo'; preserving node information during this session.
Warning: line 1: The mesh |Layout|Fruit|Figs_GRP|Gold_Figs_04_UVd|Gold_Figs_04_UVdShape contains invalid or unused components. These can be cleaned up using the Mesh Cleanup dialog.
Warning: line 1: Errors have occurred while reading this scene that may result in data loss.
File read in 28.6 seconds.
Result: D:/_Projects/Mydas/Maya/scenes/Mydas_Rendering_turnaround_03_v10.mb
Warning: file: E:/_Programs/Autodesk/Maya2023/scripts/others/makeCameraRenderable.mel line 45: Found camera Mydas_Detail_CAM_Shape2.
Exporting Arnold Scene...
Exporting Motion Data...
Updating Arnold Scene...
00:01:27 7389MB WARNING | unable to create log file C:/Users/Paolo Giandoso/Documents/maya/mayaLog_detail.11.*: Invalid argument
00:01:27 7389MB | log started Mon Nov 28 14:32:28 2022
00:01:27 7389MB | Arnold 7.1.3.2 [2a385cac] windows clang-10.0.1 oiio-2.4.1 osl-1.12.0 vdb-7.1.1 adlsdk-6.3.1.44 clmhub-2.0.0.235 rlm-14.1.3 optix-6.6.0 2022/09/12 08:50:17
00:01:27 7389MB | host application: MtoA 5.2.1.1 6a048927 (fix-5.2.1) Maya 2023
00:01:27 7389MB | running on PaoloWorkStation, pid=55008
00:01:27 7389MB | 1 x Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz (4 cores, 8 logical) with 65476MB
00:01:27 7389MB | NVIDIA driver version 526.98 (Optix 60805)
00:01:27 7389MB | GPU 0: NVIDIA GeForce RTX 3090 @ 1740MHz (compute 8.6) with 24575MB (22357MB available) (NVLink:0)
00:01:27 7389MB | Windows 10 (version 10.0, build 19045)
00:01:27 7389MB | soft limit for open files is set at 2048
00:01:27 7389MB |
00:01:27 7389MB |
00:01:27 7389MB | authorizing with license manager: user ...
00:01:29 7392MB | [user] authorized user "giandosopaolo" in 0:01.73
00:01:29 7392MB | [user] expiration date: 2022-12-08T16:09:39Z
00:01:29 7392MB |
00:01:29 7401MB | [gpu] setting OptiX disk cache location to: C:\Users\Paolo Giandoso\AppData\Local/NVIDIA/OptixCache/arnold
00:01:29 7597MB | GPU 0: NVIDIA GeForce RTX 3090 enabled
00:01:29 7597MB | [color_manager] using color manager of type "color_manager_ocio"
00:01:29 7598MB | [color_manager_ocio] using config file E:/_Programs/Autodesk/Maya2023/resources/OCIO-configs/Maya2022-default/config.ocio
00:01:29 7598MB | [color_manager] rendering color space is "ACEScg"
00:01:29 7620MB |
00:01:29 7620MB | there are 7 lights and 140 objects:
00:01:29 7620MB | 12 persp_camera
00:01:29 7620MB | 4 quad_light
00:01:29 7620MB | 1 spot_light
00:01:29 7620MB | 1 skydome_light
00:01:29 7620MB | 1 disk_light
00:01:29 7620MB | 172 image
00:01:29 7620MB | 1 noise
00:01:29 7620MB | 2 utility
00:01:29 7620MB | 66 standard_surface
00:01:29 7620MB | 2 bump2d
00:01:29 7620MB | 1 atmosphere_volume
00:01:29 7620MB | 141 color_correct
00:01:29 7620MB | 1 layer_float
00:01:29 7620MB | 2 multiply
00:01:29 7620MB | 47 normal_map
00:01:29 7620MB | 50 range
00:01:29 7620MB | 2 shuffle
00:01:29 7620MB | 7 uv_transform
00:01:29 7620MB | 1 driver_exr
00:01:29 7620MB | 1 imager_denoiser_oidn
00:01:29 7620MB | 1 imager_lens_effects
00:01:29 7620MB | 1 imager_tonemap
00:01:29 7620MB | 1 gaussian_filter
00:01:29 7620MB | 1 variance_filter
00:01:29 7620MB | 127 polymesh
00:01:29 7620MB | 12 procedural
00:01:29 7620MB | 2 list_aggregate
00:01:29 7620MB | 3 color_manager_ocio
00:01:29 7620MB | 7 merge
00:01:29 7620MB | 14 set_parameter
00:01:29 7620MB | 10 disable
00:01:29 7620MB |
00:01:29 7620MB | rendering image at 1920 x 1080 (769 x 1081 region), 3 AA samples
00:01:29 7620MB | AA samples max 20
00:01:29 7620MB | AA adaptive threshold 0.02
00:01:29 7620MB | AA sample clamp 3
00:01:29 7620MB | diffuse samples 3 / depth 3
00:01:29 7620MB | specular samples 4 / depth 3
00:01:29 7620MB | transmission samples 2 / depth 8
00:01:29 7620MB | volume indirect samples 1 / depth 1
00:01:29 7620MB | total depth 10
00:01:29 7620MB | bssrdf samples 4
00:01:29 7620MB | transparency depth 10
00:01:29 7620MB | initializing 692 nodes
00:01:29 7620MB WARNING | /Turnaround_CAM_03_GRP/Turnaround_CAM_03/Turnaround_CAM_03Shape: ignoring scaling component in camera matrix
00:01:30 7572MB WARNING | [ass] line 275: ignoring /Turnaround_CAM_01/Turnaround_CAM_01Shape.lens_tilt_angle (expected 4 values for array type VECTOR2 but found 2)
00:01:30 7573MB WARNING | [ass] line 275: /Turnaround_CAM_01/Turnaround_CAM_01Shape.-nan: unknown '-nan' parameter
00:01:30 7574MB WARNING | [ass] line 277: ignoring /Turnaround_CAM_01/Turnaround_CAM_01Shape.lens_shift (expected 4 values for array type VECTOR2 but found 2)
00:01:30 7575MB WARNING | [ass] line 277: /Turnaround_CAM_01/Turnaround_CAM_01Shape.-nan: unknown '-nan' parameter
00:01:30 7679MB WARNING | resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:30 7695MB WARNING | resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:30 7701MB WARNING | resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:30 7713MB WARNING | resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:30 7726MB WARNING | resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:31 7955MB | creating root object list ...
00:01:31 7955MB | node initialization done in 0:01.11 (multithreaded)
00:01:31 7955MB | updating 751 nodes
00:01:31 7955MB | /aiSkyDomeLight1/aiSkyDomeLightShape1: skydome_light using 3 samples, 2 volume samples
00:01:31 7955MB | /AreaLight/aiAreaLight1: disk_light using 4 samples, 2 volume samples
00:01:31 7956MB | /Mydas_Face_Light_02/Mydas_Face_Light_02Shape: quad_light using 2 samples, disabled for volumes
00:01:31 7956MB | /Mydas_Face_Light_01/Mydas_Face_Light_01Shape: quad_light using 2 samples, 2 volume samples (shadows off)
00:01:31 7956MB | /SpotLight1/spotLightShape3: spot_light using 4 samples, 2 volume samples
00:01:31 7957MB | /Mydas_Face_Light_03/Mydas_Face_Light_03Shape: quad_light using 2 samples, disabled for volumes
00:01:31 7958MB | /Mydas_Mouth_Light/Mydas_Mouth_LightShape: quad_light using 1 sample (shadows off), 2 volume samples (shadows off)
00:01:31 7964MB | [color_manager_ocio] using config file E:\_Programs\Autodesk\Arnold\maya2023\bin\../ocio/configs/arnold/config.ocio
00:01:31 7974MB | scene bounds: (-6355.71387 -114.600082 -6319.23291) -> (6307.54736 6858.94385 19247.7656)
00:01:31 7974MB | node update done in 0:00.15 (multithreaded)
00:01:31 7974MB | [quad_light] /Mydas_Face_Light_03/Mydas_Face_Light_03Shape: 128x128 importance map done in 0:00.00, average energy 0.180900
00:01:31 7974MB | [gpu] preparing 751 nodes
00:01:39 14343MB WARNING | [disp] /Layout/Fruit/Oranges_GRP/Gold_StalkOrange_03_UVd/Gold_StalkOrange_03_UVdShape: padding is at least 1.9x smaller than it should be! given disp_padding: 0.136403799, recommended: 0.259114981
00:04:03 23884MB | [gpu] updating 751 nodes
00:04:17 24296MB | [aov] parsing 12 output statements ...
00:04:17 24296MB WARNING | [gpu] variance_filter ("defaultArnoldRenderOptions/variance_filter") not supported on the GPU
00:04:17 24400MB | [aov] registered driver: "defaultArnoldDriver/driver_exr.RGBA" (driver_exr)
00:04:17 24400MB | [aov] * "RGBA" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "Mask" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "Mask_Hair" of type RGBA filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "denoise_albedo_noisy" of type RGB filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "diffuse" of type RGB filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "emission" of type RGB filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "specular" of type RGB filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "sss" of type RGB filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "Z" of type FLOAT filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "N" of type VECTOR filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] * "denoise_albedo" of type RGB filtered by "defaultArnoldFilter/gaussian_filter" (gaussian_filter)
00:04:17 24400MB | [aov] done preparing 12 AOVs for 20 outputs to 1 driver (0 deep AOVs)
00:04:17 24645MB WARNING | [imagers] forcing box filter due to usage of OptiX/OIDN imager
00:04:17 24762MB | starting render
00:04:17 24769MB | [gpu] compiling shaders
00:04:53 29232MB | [gpu] shader compilation done in 0:35.749
00:04:57 32237MB | 0% done -- estimated remaining time = 1845.8s
00:22:34 26463MB | 5% done -- estimated remaining time = 23202.3s
00:40:13 14056MB | 10% done -- estimated remaining time = 16215.3s
14 REPLIES 14
Message 2 of 15
Can you post the stats from the bottom of the log? The stuff like the "top session self-times"
// Stephen Blair
// Arnold Renderer Support
Message 3 of 15
01:33:41 6358MB | 30% done -- estimated remaining time = 12228.1s
01:49:04 6472MB | 35% done -- estimated remaining time = 12183.7s
02:05:19 6516MB | 40% done -- estimated remaining time = 12065.3s
02:21:33 7564MB | 45% done -- estimated remaining time = 10094.6s
02:37:39 7346MB | 50% done -- estimated remaining time = 10072.6s
02:55:20 9912MB | 55% done -- estimated remaining time = 10376.9s
03:38:10 7272MB | 60% done -- estimated remaining time = 16427.4s
04:05:44 7425MB | 65% done -- estimated remaining time = 1101.4s
04:05:44 7425MB | 100% done -- estimated remaining time = 0.0s
04:05:44 7752MB | render done in 4:01:26.791
04:05:54 8750MB | [driver_exr] writing file `D:/_Projects/Mydas/Maya/images/Faces/Mydas_Face_Mydas_003b_iRender_0011.exr'
04:05:54 8767MB | render done
04:05:54 8769MB |
04:05:54 8769MB | -----------------------------------------------------------------------------------
04:05:54 8769MB | scene creation time 1:27.80 machine utilization (2.69%)
04:05:54 8769MB | unaccounted 1:27.80
04:05:54 8769MB | frame time 4:04:26.82 machine utilization (17.84%)
04:05:54 8769MB | node init 0:01.27
04:05:54 8769MB | sanity checks 0:00.27
04:05:54 8769MB | ass parsing (procs) 0:00.08
04:05:54 8769MB | driver init/close 0:10.61
04:05:54 8769MB | subdivision 0:22.97
04:05:54 8769MB | threads blocked 0:00.09
04:05:54 8769MB | mesh processing 0:34.54
04:05:54 8769MB | displacement 1:18.05
04:05:54 8769MB | threads blocked 0:37.45
04:05:54 8769MB | gpu prepare 2:32.58
04:05:54 8769MB | gpu update 0:13.27
04:05:54 8769MB | gpu jit compile / BVH 0:35.74
04:05:54 8769MB | rendering 4:00:51.04
04:05:54 8769MB | output driver 0:00.02
04:05:54 8769MB | pixel rendering 4:00:51.01 (423 sample iterations @ min: 0:00.065, avg: 0:34.163, max: 2:41.595)
04:05:54 8769MB | unaccounted -2:13.28
04:05:54 8769MB | top session self-times by category
04:05:54 8769MB | top session self-times by node
04:05:54 8769MB | peak CPU memory used 37461.75MB
04:05:54 8769MB | at startup 1075.66MB
04:05:54 8769MB | AOV samples 147.15MB
04:05:54 8769MB | output buffers 7.00MB
04:05:54 8769MB | framebuffers 221.00MB
04:05:54 8769MB | node overhead 0.64MB
04:05:54 8769MB | message passing 0.02MB
04:05:54 8769MB | memory pools 14.05MB
04:05:54 8769MB | geometry 11911.09MB
04:05:54 8769MB | polymesh 55.63MB
04:05:54 8769MB | subdivs 11412.53MB
04:05:54 8769MB | curves 442.93MB
04:05:54 8769MB | quad importance map 0.13MB
04:05:54 8769MB | strings 24.25MB
04:05:54 8769MB | texture cache 4096.00MB
04:05:54 8769MB | unaccounted 19964.76MB
04:05:54 8769MB | peak GPU memory consumed 22705.65MB
04:05:54 8769MB | output buffers 127.41MB
04:05:54 8769MB | geometry 16035.40MB
04:05:54 8769MB | polymesh 88.08MB
04:05:54 8769MB | subdivs 15452.50MB
04:05:54 8769MB | curves 494.82MB
04:05:54 8769MB | texture cache 2148.11MB
04:05:54 8769MB | unaccounted 4394.74MB
04:05:54 8769MB | ray counts ( /pixel, /sample) (% total) (avg. hits) (max hits)
04:05:54 8769MB | camera 328612273 ( 0.93, 1.00) ( 1.54%) ( 0.98) ( 1)
04:05:54 8769MB | shadow xxx-xxxxxxxx ( 49.67, 53.13) ( 81.60%) ( 0.67) ( 1)
04:05:54 8769MB | diffuse_reflect 150928600 ( 0.43, 0.46) ( 0.71%) ( 0.98) ( 1)
04:05:54 8769MB | diffuse_transmit 63018 ( 0.00, 0.00) ( 0.00%) ( 0.97) ( 1)
04:05:54 8769MB | specular_reflect 445677590 ( 1.27, 1.36) ( 2.08%) ( 0.99) ( 1)
04:05:54 8769MB | bssrdf 3012767649 ( 8.57, 9.17) ( 14.08%) ( 0.05) ( 1)
04:05:54 8769MB | total xxx-xxxxxxxx ( 60.87, 65.11) (100.00%) ( 0.60) ( 1)
04:05:54 8769MB | by ray depth: 0 1 2 3 4 5 6 7
04:05:54 8769MB | total 56.1% 24.1% 11.7% 6.3% 1.4% 0.3% 0.0% 0.0%
04:05:54 8769MB | meshes 94
04:05:54 8769MB | shader calls 172642420
04:05:54 8769MB | geometry (% hit ) (instances) ( init mem, final mem)
04:05:54 8769MB | lists 1 (100.0%) ( 0) ( 0.00, 0.00)
04:05:54 8769MB | procs 12 (100.0%) ( 0) ( 0.00, 0.00)
04:05:54 8769MB | polymeshes 21 (100.0%) ( 0) ( 55.67, 55.63)
04:05:54 8769MB | subdivs 106 (100.0%) ( 0) ( 562.14, 11412.53)
04:05:54 8769MB | curves 12 (100.0%) ( 0) ( 442.93, 442.93)
04:05:54 8769MB | curves 9 had pixel-width optimization
04:05:54 8769MB | geometric elements ( min) ( avg.) ( max)
04:05:54 8769MB | objects (procs) 12 ( 1) ( 1.0) ( 1)
04:05:54 8769MB | polygons 1444125 ( 😎 ( 68767.9) ( 598005)
04:05:54 8769MB | subdiv patches 17810774 ( 60) ( 168026.2) ( 1209576)
04:05:54 8769MB | curves 551196 ( 614) ( 45933.0) ( 177096)
04:05:54 8769MB | curve segments 10402866 ( 1842) ( 866905.5) ( 6302439)
04:05:54 8769MB | triangle tessellation ( min) ( avg.) ( max) (/ element) (% total)
04:05:54 8769MB | polymeshes 2882572 ( 16) ( 137265.3) ( 1191390) ( 2.00) ( 0.81%)
04:05:54 8769MB | subdivs 353441793 ( 200) ( 3334356.5) (102799176) ( 19.84) ( 99.19%)
04:05:54 8769MB | adaptive 353441793 ( 200) ( 3334356.5) (102799176) ( 19.84) ( 99.19%)
04:05:54 8769MB | unique triangles 356324365
04:05:54 8769MB | CPU memory use 11468.16MB
04:05:54 8769MB | vertices 2355.49MB
04:05:54 8769MB | vertex indices 2133.78MB
04:05:54 8769MB | polygon base offsets 0.00MB
04:05:54 8769MB | polygon IDs 0.00MB
04:05:54 8769MB | triangulation 0.00MB
04:05:54 8769MB | packed normals 783.80MB
04:05:54 8769MB | normal indices 10.58MB
04:05:54 8769MB | uv coords 714.10MB
04:05:54 8769MB | uv coords idxs 2122.44MB
04:05:54 8769MB | P reference (autobump) 2206.01MB
04:05:54 8769MB | N reference (autobump) 735.34MB
04:05:54 8769MB | uniform indices 401.22MB
04:05:54 8769MB | userdata 0.96MB
04:05:54 8769MB | GPU memory use 15540.58MB
04:05:54 8769MB | vertex indices 6211.58MB
04:05:54 8769MB | normals 783.80MB
04:05:54 8769MB | uv coords idxs 2122.43MB
04:05:54 8769MB | other 0.02MB
04:05:54 8769MB | largest polymeshes by triangle count
04:05:54 8769MB | 102799176 tris -- /Layout/Mydas_posed_UVd/Mydas_Hymation_exported_UVd/Mydas_Hymation_exported_UVdShape
04:05:54 8769MB | 69753054 tris -- /Layout/Mydas_posed_UVd/Mydas_Chyton_extruded_UVd/Mydas_Chyton_extruded_UVdShape
04:05:54 8769MB | 36067486 tris -- /Layout/Dora_GRP/Peplos_extruded_UVd_02/Peplos_extruded_UVd_02Shape
04:05:54 8769MB | 31119134 tris -- /Layout/Room_GRP/Floor_Sides/Floor_SidesShape
04:05:54 8769MB | 21803384 tris -- /Layout/Floor_Center/Floor_CenterShape
04:05:54 8769MB | ass file cache
04:05:54 8769MB | unique (loaded from disk) 12 (100.00%)
04:05:54 8769MB | reused (found in cache) 0 (0.00%)
04:05:54 8769MB | total referenced .ass files 12 (100.00%)
04:05:54 8770MB | OpenImageIO Texture statistics
04:05:54 8770MB | Options: gray_to_rgb=true flip_t=false max_tile_channels=6
04:05:54 8770MB | Queries/batches :
04:05:54 8770MB | texture : 172642461 queries in 172642461 batches
04:05:54 8770MB | texture 3d : 0 queries in 0 batches
04:05:54 8770MB | shadow : 0 queries in 0 batches
04:05:54 8770MB | environment : 0 queries in 0 batches
04:05:54 8770MB | gettextureinfo : 0 queries
04:05:54 8770MB | Interpolations :
04:05:54 8770MB | closest : 41
04:05:54 8770MB | bilinear : 136293864
04:05:54 8770MB | bicubic : 187809942
04:05:54 8770MB | Average anisotropic probes : 1.34
04:05:54 8770MB | Max anisotropy in the wild : 3.78e+05
04:05:54 8770MB |
04:05:54 8770MB | OpenImageIO ImageCache statistics (0000019B7BA3C040) ver 2.4.1.1dev
04:05:54 8770MB | Options: max_memory_MB=4096.0 max_open_files=1536 autotile=0
04:05:54 8770MB | autoscanline=true automip=false forcefloat=false
04:05:54 8770MB | accept_untiled=true accept_unmipped=true deduplicate=true
04:05:54 8770MB | unassociatedalpha=false failure_retries=0 openexr:core=0
04:05:54 8770MB | Images : 206 unique
04:05:54 8770MB | ImageInputs : 206 created, 204 current, 204 peak
04:05:54 8770MB | Total pixel data size of all images referenced : 22.7 GB
04:05:54 8770MB | Total actual file size of all images referenced : 10.0 GB
04:05:54 8770MB | Pixel data read : 4.4 GB
04:05:54 8770MB | File I/O time : 28m 37.7s (1m 41.0s average per thread, for 17 threads)
04:05:54 8770MB | File open time only : 3.3s
04:05:54 8770MB | ImageInput mutex locking time : 0.4s
04:05:54 8770MB | Tiles: 267617 created, 239613 current, 239709 peak
04:05:54 8770MB | total tile requests : 435146698
04:05:54 8770MB | micro-cache misses : 1487426 (0.3%)
04:05:54 8770MB | main cache misses : 267617 (0.1%)
04:05:54 8770MB | redundant reads: 20 tiles, 440 KB
04:05:54 8770MB | Peak cache memory : 4.0 GB
04:05:54 8770MB | Image file statistics:
04:05:54 8770MB | opens tiles MB read --redundant-- I/O time res File
04:05:54 8770MB | 1 1 158 3.7 0.1s 1024x1024x3.f16 C:/Users/paolog/Desktop/Mydas/Maya/sourceimages/MydasScalpShape_Mydas_Grooming_01_Mydas_Hair_01_color.tx MIP-UNUSED MIP-COUNT[158,0,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 2 1 136 1.1 0.0s 1024x1024x1.f16 C:/Users/paolog/Desktop/Mydas/Maya/sourceimages/Mydas_scalp_beardShape_Mydas_Grooming_01_Mydas_Beard_01_Color_mask.tx MIP-UNUSED MIP-COUNT[136,0,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 3 1 32 0.2 0.0s 1024x1024x1.f16 D:/_Projects/Mydas/Maya/sourceimages/Mydas_scalp_eyebrowsShape_Mydas_Grooming_01_Mydas_Eyebrows_01_MydasHairbrows_01_Color_mask.tx MIP-UNUSED MIP-COUNT[32,0,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 4 1 2320 36.2 0.7s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Apples_01_DSP_8k_32bit.tx MIP-COUNT[885,687,482,195,56,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 5 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Apples_Gold_Normal_1001.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:54 8770MB | 6 1 11 0.0 0.3s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Apples_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 7 1 9904 154.8 2.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Baguette_01_DSP_8k_32bit.tx MIP-COUNT[6722,2300,638,177,52,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 8 1 9869 154.2 2.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Baguette_02_DSP_8k_32bit.tx MIP-COUNT[6683,2304,637,178,52,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 9 1 10310 161.1 2.7s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Baguette_03_DSP_8k_32bit.tx MIP-COUNT[7169,2260,636,178,52,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 10 1 10470 163.6 2.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Bread_01_DSP_8k_32bit.tx MIP-COUNT[7219,2302,680,196,57,15,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 11 1 10635 166.2 2.6s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Bread_02_DSP_8k_32bit.tx MIP-COUNT[7391,2292,683,196,57,15,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 12 1 4858 75.9 1.3s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_01_DSP_8k_32bit.tx MIP-COUNT[2464,1483,651,187,52,16,4,0,0,0,0,0,0,1]
04:05:54 8770MB | 13 1 1749 27.3 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_02_DSP_8k_32bit.tx MIP-COUNT[531,553,474,136,40,11,3,0,0,0,0,0,0,1]
04:05:54 8770MB | 14 1 2087 32.6 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_03_DSP_8k_32bit.tx MIP-COUNT[993,560,348,133,38,12,2,0,0,0,0,0,0,1]
04:05:54 8770MB | 15 1 4844 75.7 2.2s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_04_DSP_8k_32bit.tx MIP-COUNT[2462,1472,651,186,52,16,4,0,0,0,0,0,0,1]
04:05:54 8770MB | 16 1 4681 73.1 1.3s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Breadloaf_05_DSP_8k_32bit.tx MIP-COUNT[2242,1449,710,203,56,16,4,0,0,0,0,0,0,1]
04:05:54 8770MB | 17 1 420 6.6 0.1s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Butter_DSP_8k_32bit.tx MIP-COUNT[96,136,124,45,14,4,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 18 1 425 10.0 10.1s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Cup_01_8k_8bit_ALB.tx MIP-COUNT[220,102,52,26,14,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 19 1 535 6.3 10.5s 8192x8192x3.u8 D:/_Projects/Mydas/Textures/Cup_01_8k_8bit_NRM.tx MIP-COUNT[0,264,132,72,40,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 20 1 27 0.1 0.0s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Cup_01_8k_8bit_RGH.tx MIP-COUNT[0,0,0,0,0,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 21 1 2622 41.0 0.4s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Cup_01_DSP_8k_32bit.tx MIP-COUNT[771,793,773,226,58,0,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 22 1 27 0.3 0.7s 4096x4096x3.u8 D:/_Projects/Mydas/Textures/Cup_01_MSK_8k_8bit.tx MIP-COUNT[0,0,0,0,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 23 1 2138 16.7 0.4s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Cup_02_Gold_Height.1001.tx MIP-COUNT[1169,742,197,30,0,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 24 1 989 23.2 32.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Cup_02_Gold_Normal.1001.tx MIP-COUNT[544,236,128,54,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 25 1 1563 6.1 4.6s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Cup_02_Gold_Roughness.1001.tx MIP-COUNT[800,448,224,64,16,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 26 1 8484 132.6 1.3s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Cup_03_DSP_8k_32bit.tx MIP-COUNT[5185,2153,846,235,50,14,0,0,0,0,0,0,0,1]
04:05:54 8770MB | 27 1 81 1.9 1.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Cup_03_Shattered_8k_8bit_ALB.tx MIP-COUNT[0,18,22,20,10,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 28 1 111 1.3 1.7s 8192x8192x3.u8 D:/_Projects/Mydas/Textures/Cup_03_Shattered_8k_8bit_NRM.tx MIP-COUNT[0,0,28,32,28,12,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 29 1 11 0.0 0.0s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Cup_03_Shattered_8k_8bit_RGH.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 30 1 1456 11.4 0.2s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Cup_04_Height.1001.tx MIP-COUNT[571,604,217,48,16,0,0,0,0,0,0,0,0]
04:05:54 8770MB | 31 1 7 0.2 0.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Cup_04_Normal.1001.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:54 8770MB | 32 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Cup_04_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:54 8770MB | 33 1 91 2.1 2.9s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Curtains_4K_Albedo.tx MIP-COUNT[0,0,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 34 1 91 1.1 0.4s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/Curtains_4K_Normal.tx MIP-COUNT[0,0,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 35 1 1024 16.0 0.1s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u0_v0.tx MIP-COUNT[289,433,223,62,16,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 36 1 2885 45.1 0.8s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u1_v0.tx MIP-COUNT[2088,614,161,17,4,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 37 1 2891 45.2 0.5s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u2_v0.tx MIP-COUNT[1916,733,215,23,3,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 38 1 2267 35.4 0.4s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u3_v0.tx MIP-COUNT[1194,785,222,60,5,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 39 1 1378 21.5 0.2s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Dora_01_DSP_4k_32bit.u4_v0.tx MIP-COUNT[568,499,228,62,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 40 1 791 18.5 35.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1001.tx MIP-COUNT[450,204,82,28,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 41 1 373 8.7 10.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1002.tx MIP-COUNT[198,84,40,28,12,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 42 1 113 2.6 4.6s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1003.tx MIP-COUNT[40,30,14,8,10,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 43 1 103 2.4 3.3s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1004.tx MIP-COUNT[32,18,14,16,12,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 44 1 7 0.2 0.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Normal.1005.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 45 1 1179 4.6 6.7s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1001.tx MIP-COUNT[704,304,112,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 46 1 699 2.7 2.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1002.tx MIP-COUNT[320,208,80,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 47 1 379 1.5 1.4s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1003.tx MIP-COUNT[160,96,64,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 48 1 251 1.0 1.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1004.tx MIP-COUNT[64,64,48,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 49 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Dora_Body_Gold_Roughness.1005.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 50 1 2230 17.4 ( 1 0.0) 1.1s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Dora_Peplos_Gold_Height.1001.tx MIP-COUNT[1984,213,17,8,8,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 51 1 421 9.9 17.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Dora_Peplos_Gold_Normal.1001.tx MIP-COUNT[184,110,68,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 52 1 699 5.5 8.4s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/Dora_Peplos_Gold_Roughness.1001.tx MIP-COUNT[328,184,112,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 53 1 662 15.5 1.5s 1600x1200x3.f16 D:/_Projects/Mydas/Textures/Fabric_normalMap_02_details.tx MIP-COUNT[475,130,35,12,4,1,1,1,1,1,1]
04:05:55 8770MB | 54 1 640 15.0 14.2s 1399x1399x3.f16 D:/_Projects/Mydas/Textures/Fabric_normalMap_details.tx MIP-COUNT[464,121,36,9,4,1,1,1,1,1,1]
04:05:55 8770MB | 55 1 1171 9.1 0.1s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/Figs_8k_DSP.tx MIP-COUNT[378,287,265,166,54,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 56 1 11 0.0 0.0s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Figs_Gold_Metalness_1001.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 57 1 11 0.0 0.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Figs_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 58 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Figs_NRM_DirectX.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 59 1 2437 76.2 1m 52.1s 8192x8192x4.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Base_Color.tx MIP-COUNT[0,1754,452,150,54,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 60 1 9507 74.3 3.0s 8192x8192x1.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Height.tx MIP-COUNT[4831,3875,777,24,0,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 61 1 2437 76.2 58.4s 8192x8192x4.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Normal_DirectX.tx MIP-COUNT[0,1754,452,150,54,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 62 1 435 3.4 3.6s 8192x8192x1.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Roughness.tx MIP-COUNT[0,64,112,168,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 63 1 5467 170.8 3m 34.9s 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Base_Color.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 64 1 4712 36.8 3.7s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Height.tx MIP-COUNT[3376,1024,256,56,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 65 1 5467 170.8 27.4s 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Normal_DirectX.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 66 1 539 4.2 4.6s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Roughness.tx MIP-COUNT[24,176,248,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 67 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Fruit_LP_forSubstance_B_Ribes_SG_Normal_1001.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 68 1 4292 67.1 0.9s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Jewels_DSP_8k_32bit.tx MIP-COUNT[2068,1238,674,236,64,9,2,0,0,0,0,0,0,1]
04:05:55 8770MB | 69 1 1650 25.8 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Knife_DSP_8k_32bit.tx MIP-COUNT[639,568,316,100,26,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 70 1 379 3.0 0.9s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/Knife_Gold_Roughness_01.tx MIP-COUNT[24,184,112,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 71 1 4579 71.5 0.9s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/L_Shoe_DSP_8k_32bit.tx MIP-COUNT[3343,929,250,55,1,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 72 1 1635 25.5 0.5s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Lemons_01_DSP_8k_32bit.tx MIP-COUNT[564,435,325,228,62,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 73 1 11 0.1 0.2s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/Lemons_Gold_Metalness_1001.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 74 1 7 0.2 0.0s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Lemons_Gold_Normal_1001.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 75 1 11 0.1 0.0s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/Lemons_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 76 1 1883 29.4 ( 1 0.0) 0.8s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u0_v0.tx MIP-COUNT[890,677,227,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 77 1 2899 45.3 ( 1 0.0) 0.7s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u1_v0.tx MIP-COUNT[2093,626,161,18,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 78 1 2706 42.3 0.5s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u2_v0.tx MIP-COUNT[1835,667,181,22,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 79 1 2718 42.5 0.4s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u3_v0.tx MIP-COUNT[1747,739,208,23,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 80 1 629 9.8 ( 1 0.0) 0.3s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u4_v0.tx MIP-COUNT[322,211,67,22,6,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 81 1 15 0.4 0.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_L_Shoe_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,4,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 82 1 27 0.1 0.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_L_Shoe_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 83 1 7 0.2 0.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_R_Shoe_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 84 1 11 0.0 0.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_R_Shoe_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 85 1 7 0.2 0.5s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_Shoes_Oraments_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 86 1 11 0.1 0.1s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/Mydas_Shoes_Oraments_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 87 1 2833 66.4 1m 25.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1001.tx MIP-COUNT[1872,668,204,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 88 1 475 11.1 15.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1002.tx MIP-COUNT[280,90,54,26,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 89 1 13 0.3 0.7s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1003.tx MIP-COUNT[0,0,0,2,2,2,1,1,1,1,1,1,1]
04:05:55 8770MB | 90 1 633 14.8 18.5s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1004.tx MIP-COUNT[368,142,60,36,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 91 1 2317 54.3 1m 30.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/Mydas_body_BaseColor.1005.tx MIP-COUNT[1324,658,242,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 92 1 1259 4.9 0.2s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Coat.1001.tx MIP-COUNT[912,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 93 1 2835 66.4 2m 12.3s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1001.tx MIP-COUNT[1874,668,204,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 94 1 475 11.1 18.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1002.tx MIP-COUNT[280,90,54,26,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 95 1 13 0.3 0.9s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1003.tx MIP-COUNT[0,0,0,2,2,2,1,1,1,1,1,1,1]
04:05:55 8770MB | 96 1 633 14.8 24.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1004.tx MIP-COUNT[368,142,60,36,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 97 1 969 22.7 26.5s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1005.tx MIP-COUNT[636,208,74,28,12,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 98 1 1675 6.5 3.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1001.tx MIP-COUNT[976,448,160,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 99 1 235 0.9 0.6s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1002.tx MIP-COUNT[96,48,32,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 100 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1003.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 101 1 523 2.0 1.5s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1004.tx MIP-COUNT[192,144,96,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 102 1 1051 4.1 0.4s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_Roughness.1005.tx MIP-COUNT[288,416,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 103 1 3835 15.0 6.9s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1001.tx MIP-COUNT[2576,912,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 104 1 955 3.7 1.7s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1002.tx MIP-COUNT[544,256,80,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 105 1 43 0.2 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1003.tx MIP-COUNT[0,0,0,16,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 106 1 1099 4.3 3.1s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1004.tx MIP-COUNT[608,272,128,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 107 1 1403 5.5 0.5s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_body_ScatterWeight.1005.tx MIP-COUNT[896,320,128,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 108 1 16107 125.8 1.8s 8192x8192x1.u16 D:/_Projects/Mydas/Textures/Mydas_clothes_04_8k_16bit_DSP.tx MIP-COUNT[13685,2264,74,40,24,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 109 1 1 384.0 2.5s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Mydas_clothes_Gold_Normal.1001_a.png UNTILED
04:05:55 8770MB | 110 1 1 64.0 0.6s 8192x8192x1.u8 D:/_Projects/Mydas/Textures/Mydas_clothes_Gold_Roughness.1001_02.png UNTILED
04:05:55 8770MB | 111 1 2569 60.2 1m 52.0s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_crown_Gold_Normal.1001.tx MIP-COUNT[1500,734,244,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 112 1 4379 17.1 13.4s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_crown_Gold_Roughness.1001.tx MIP-COUNT[3024,1008,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 113 1 787 18.4 1m 11.4s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_jewels_Gold_Normal.1001_b.tx MIP-COUNT[430,200,92,38,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 114 1 1355 5.3 4.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_jewels_Gold_Roughness.1001.tx MIP-COUNT[720,352,192,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 115 1 11 0.3 0.2s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_rings_Gold_Normal.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 116 1 11 0.0 0.2s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Mydas_rings_Gold_Roughness.1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 117 1 880 13.8 0.2s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Oranges_01_DSP_8k_32bit.tx MIP-COUNT[214,192,200,190,62,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 118 1 29 0.7 1.3s 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Oranges_Gold_Normal_1001.tx MIP-COUNT[0,0,8,8,4,2,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 119 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Oranges_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 120 1 4560 71.2 0.8s 4096x4096x1.f32 D:/_Projects/Mydas/Textures/R_Shoe_DSP_8k_32bit.tx MIP-COUNT[3312,930,250,62,5,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 121 1 6838 106.8 2.8s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Ribes_01_DSP_8k_32bit.tx MIP-COUNT[3855,1866,779,253,64,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 122 1 11 0.0 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Ribes_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 123 1 3754 58.7 0.8s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Rings_DSP_8k_32bit.tx MIP-COUNT[2080,819,557,218,60,15,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 124 1 763 17.9 6.9s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Balconies_BaseColor.1001.tx MIP-COUNT[556,124,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 125 1 499 11.7 8.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Balconies_BaseColor.1002.tx MIP-COUNT[328,102,42,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 126 1 763 17.9 20.2s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Balconies_Normal.1001.tx MIP-COUNT[556,124,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 127 1 499 11.7 11.2s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Balconies_Normal.1002.tx MIP-COUNT[328,102,42,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 128 1 475 1.9 0.6s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Balconies_Roughness.1001.tx MIP-COUNT[192,192,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 129 1 427 1.7 0.7s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Balconies_Roughness.1002.tx MIP-COUNT[224,112,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 130 1 1159 27.2 29.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Cieling_1stFloor_BaseColor.1001.tx MIP-COUNT[826,242,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 131 1 1159 27.2 23.9s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Cieling_1stFloor_Normal.1001.tx MIP-COUNT[826,242,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 132 1 1003 3.9 2.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Cieling_1stFloor_Roughness.1001.tx MIP-COUNT[656,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 133 1 893 20.9 21.2s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Columns_BaseColor.1001.tx MIP-COUNT[626,184,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 134 1 893 20.9 14.2s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Columns_Normal.1001.tx MIP-COUNT[626,184,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 135 1 411 1.6 0.9s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Columns_Roughness.1001.tx MIP-COUNT[128,192,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 136 1 343 8.0 4.7s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_PavementInside_BaseColor.1001.tx MIP-COUNT[192,90,34,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 137 1 665 5.2 0.1s 2048x2048x1.u16 D:/_Projects/Mydas/Textures/Room_PavementInside_Height.1001.tx MIP-COUNT[644,21,0,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 138 1 343 8.0 3.8s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_PavementInside_Normal.1001.tx MIP-COUNT[192,90,34,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 139 1 427 1.7 1.1s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_PavementInside_Roughness.1001.tx MIP-COUNT[224,128,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 140 1 259 6.1 10.3s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_PavementOutside_BaseColor.1001.tx MIP-COUNT[140,60,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 141 1 259 6.1 8.7s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_PavementOutside_Normal.1001.tx MIP-COUNT[140,60,32,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 142 1 107 0.4 0.2s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_PavementOutside_Roughness.1001.tx MIP-COUNT[0,16,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 143 1 631 14.8 19.7s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Stone_Bench_BaseColor.1001.tx MIP-COUNT[386,158,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 144 1 633 14.8 8.7s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Stone_Bench_Normal.1001.tx MIP-COUNT[386,160,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 145 1 779 3.0 0.8s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Stone_Bench_Roughness.1001.tx MIP-COUNT[432,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 146 1 1109 26.0 13.7s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/Room_Walls_BaseColor.1001.tx MIP-COUNT[784,234,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 147 1 933 21.9 13.4s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Walls_Normal.1001.tx MIP-COUNT[640,202,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 148 1 697 16.3 22.8s 2048x2048x3.u16 D:/_Projects/Mydas/Textures/Room_Walls_Normal.1002.tx MIP-COUNT[432,180,58,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 149 1 827 3.2 1.3s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Walls_Roughness.1001.tx MIP-COUNT[480,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 150 1 251 1.0 0.6s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/Room_Walls_Roughness.1002.tx MIP-COUNT[16,144,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 151 1 5344 83.5 2.0s 8192x8192x1.f32 D:/_Projects/Mydas/Textures/Table_DSP_8k_32bit.tx MIP-COUNT[2186,2188,733,203,33,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 152 1 61 1.4 5.1s 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Table_Gold_Normal_DirectX.tx MIP-COUNT[8,20,4,10,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 153 1 203 0.8 1.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Table_Gold_Roughness.tx MIP-COUNT[48,64,16,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 154 1 1811 14.1 0.3s 4096x4096x1.u16 D:/_Projects/Mydas/Textures/Tablecoth_Gold_Height_02.tx MIP-COUNT[514,1024,256,17,0,0,0,0,0,0,0,0,0]
04:05:55 8770MB | 155 1 619 2.4 1.9s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Tablecoth_Gold_Roughness.tx MIP-COUNT[240,192,112,48,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 156 1 3967 93.0 ( 16 0.4) 1m 43.4s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/schvfgwp_4K_Albedo.tx MIP-COUNT[2644,973,259,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 157 1 43 0.2 0.0s 4096x4096x1.u8 D:/_Projects/Mydas/Textures/schvfgwp_4K_Roughness.tx MIP-COUNT[0,0,0,16,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 158 1 31 0.7 1.3s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tf3ibcppa_4K_Albedo.tx MIP-COUNT[0,10,10,4,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 159 1 31 0.7 1.5s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tf3ibcppa_4K_Normal_LOD0.tx MIP-COUNT[0,10,10,4,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 160 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/tf3ibcppa_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 161 1 7 0.2 0.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/th5jddwva_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 162 1 7 0.2 0.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/th5jddwva_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 163 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/th5jddwva_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 164 1 275 6.4 6.8s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/thmhfjkpa_4K_Albedo.tx MIP-COUNT[4,14,170,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 165 1 275 6.4 4.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/thmhfjkpa_4K_Normal_LOD0.tx MIP-COUNT[4,14,170,60,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 166 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/thmhfjkpa_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 167 1 497 11.6 10.9s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/ti0lbipqx_4K_Albedo.tx MIP-COUNT[72,198,144,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 168 1 497 11.6 14.2s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/ti0lbipqx_4K_Normal_LOD0.tx MIP-COUNT[72,198,144,56,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 169 1 43 0.3 0.5s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/ti0lbipqx_4K_Roughness.tx MIP-COUNT[0,0,8,8,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 170 1 7 0.2 0.4s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tibhfezva_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 171 1 7 0.2 0.0s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tibhfezva_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 172 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/tibhfezva_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 173 1 133 3.1 3.5s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tiwkagvva_4K_Albedo.tx MIP-COUNT[4,36,40,28,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 174 1 133 3.1 4.2s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tiwkagvva_4K_Normal_LOD0.tx MIP-COUNT[4,36,40,28,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 175 1 11 0.1 0.0s 4096x4096x1.f16 D:/_Projects/Mydas/Textures/tiwkagvva_4K_Roughness.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 176 1 7 0.2 0.4s 4096x4096x3.f16 D:/_Projects/Mydas/Textures/tl2kealva_8K_Albedo.tx MIP-COUNT[0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 177 1 7 0.2 0.0s 8192x8192x3.f16 D:/_Projects/Mydas/Textures/tl2kealva_8K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 178 1 11 0.1 0.1s 8192x8192x1.f16 D:/_Projects/Mydas/Textures/tl2kealva_8K_Roughness.tx MIP-COUNT[0,0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 179 1 359 8.4 5.3s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Albedo.tx MIP-COUNT[174,114,44,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 180 1 652 10.2 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Displacement.tx MIP-COUNT[368,203,60,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 181 1 361 8.5 7.9s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Normal_LOD0.tx MIP-COUNT[176,114,44,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 182 1 11 0.1 0.0s 2048x2048x1.f16 D:/_Projects/Mydas/Textures/tmelajvhw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 183 1 229 5.4 7.1s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Albedo.tx MIP-COUNT[116,76,18,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 184 1 777 12.1 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Displacement.tx MIP-COUNT[460,232,64,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 185 1 229 5.4 6.3s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Normal_LOD0.tx MIP-COUNT[116,76,18,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 186 1 11 0.1 0.0s 2048x2048x1.f16 D:/_Projects/Mydas/Textures/tmfiedjhw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 187 1 7 0.2 0.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 188 1 533 8.3 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Displacement.tx MIP-COUNT[286,162,63,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 189 1 7 0.1 0.0s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 190 1 11 0.0 0.1s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/ubpmajghw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 191 1 7 0.2 0.0s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Albedo.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 192 1 945 14.8 0.2s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Displacement.tx MIP-COUNT[618,242,64,16,4,0,0,0,0,0,0,1]
04:05:55 8770MB | 193 1 7 0.1 0.0s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,0,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 194 1 11 0.0 0.1s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/ubqtabsfa_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 195 1 11 0.3 0.2s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Albedo.tx MIP-COUNT[0,0,2,2,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 196 1 580 9.1 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Displacement.tx MIP-COUNT[317,177,64,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 197 1 15 0.2 0.2s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Normal_LOD0.tx MIP-COUNT[0,0,4,4,0,1,1,1,1,1,1,1]
04:05:55 8770MB | 198 1 11 0.0 0.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/uddhbemhw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 199 1 11 0.3 0.5s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Albedo.tx MIP-COUNT[0,0,0,2,2,1,1,1,1,1,1,1]
04:05:55 8770MB | 200 1 367 5.7 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Displacement.tx MIP-COUNT[185,103,57,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 201 1 15 0.2 0.6s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Normal_LOD0.tx MIP-COUNT[0,0,0,4,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 202 1 11 0.0 0.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/uddhbf2iw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 203 1 125 2.9 1.4s 2048x2048x3.f16 D:/_Projects/Mydas/Textures/uddlffshw_4K_Albedo.tx MIP-COUNT[0,70,30,14,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 204 1 433 6.8 0.1s 2048x2048x1.f32 D:/_Projects/Mydas/Textures/uddlffshw_4K_Displacement.tx MIP-COUNT[215,135,61,16,4,1,0,0,0,0,0,1]
04:05:55 8770MB | 205 1 155 1.8 1.5s 2048x2048x3.u8 D:/_Projects/Mydas/Textures/uddlffshw_4K_Normal_LOD0.tx MIP-COUNT[0,88,40,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 206 1 11 0.0 0.0s 2048x2048x1.u8 D:/_Projects/Mydas/Textures/uddlffshw_4K_Roughness.tx MIP-COUNT[0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB |
04:05:55 8770MB | Tot: 206 267617 4520.5 ( 20 0.4) 28m 37.7s
04:05:55 8770MB | 2 not tiled, 2 not MIP-mapped
04:05:55 8770MB | Top files by bytes read:
04:05:55 8770MB | 1 384.0 MB ( 8.5%) 8192x8192x3.u16 D:/_Projects/Mydas/Textures/Mydas_clothes_Gold_Normal.1001_a.png UNTILED
04:05:55 8770MB | 2 170.8 MB ( 3.8%) 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Normal_DirectX.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 3 170.8 MB ( 3.8%) 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Base_Color.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | Top files by I/O time:
04:05:55 8770MB | 1 3m 34.9s (12.5%) 4096x4096x4.u16 D:/_Projects/Mydas/Textures/Floor_Sides_8k_Base_Color.tx MIP-COUNT[4096,1024,256,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 2 2m 12.3s ( 7.7%) 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_body_Normal.1001.tx MIP-COUNT[1874,668,204,62,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 3 1m 52.1s ( 6.5%) 8192x8192x4.u16 D:/_Projects/Mydas/Textures/Floor_Center_8k_Base_Color.tx MIP-COUNT[0,1754,452,150,54,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | Files with slowest I/O rates:
04:05:55 8770MB | 1 0.16 MB/s (0.04MB/0.27s) 4096x4096x1.u8 D:/_Projects/Mydas/Textures/Apples_Gold_Roughness_1001.tx MIP-COUNT[0,0,0,0,0,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 2 0.26 MB/s (18.45MB/71.39s) 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Mydas_jewels_Gold_Normal.1001_b.tx MIP-COUNT[430,200,92,38,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 3 0.28 MB/s (1.43MB/5.09s) 4096x4096x3.u16 D:/_Projects/Mydas/Textures/Table_Gold_Normal_DirectX.tx MIP-COUNT[8,20,4,10,8,4,1,1,1,1,1,1,1]
04:05:55 8770MB | (fastest was 155.6 MB/s)
04:05:55 8770MB | Top files by redundant I/O:
04:05:55 8770MB | 1 0.4 MB (87.3%) 4096x4096x3.f16 D:/_Projects/Mydas/Textures/schvfgwp_4K_Albedo.tx MIP-COUNT[2644,973,259,64,16,4,1,1,1,1,1,1,1]
04:05:55 8770MB | 2 0.0 MB ( 3.6%) 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u4_v0.tx MIP-COUNT[322,211,67,22,6,0,0,0,0,0,0,0,1]
04:05:55 8770MB | 3 0.0 MB ( 3.6%) 4096x4096x1.f32 D:/_Projects/Mydas/Textures/Mydas_01_DSP_4k_32bit.u1_v0.tx MIP-COUNT[2093,626,161,18,0,0,0,0,0,0,0,0,1]
04:05:55 8770MB | Broken or invalid files: 0
04:05:55 8770MB | -----------------------------------------------------------------------------------
04:05:55 8770MB | number of warnings, warning type:
04:05:55 8770MB | 1: %s%s: %s
04:05:55 8770MB | 1: %s: ignoring scaling component in camera matrix
04:05:55 8770MB | 2: [ass] line %u: %s.%s: unknown '%s' parameter
04:05:55 8770MB | 2: [ass] line %u: ignoring %s.%s (expected %u values for array type %s but found %u)
04:05:55 8770MB | 1: [disp] %s: padding is at least %.3gx smaller than it should be! given disp_padding: %.9g, recommended: %.9g
04:05:55 8770MB | 1: [gpu] %s ("%s") not supported on the GPU
04:05:55 8770MB | 1: [imagers] forcing box filter due to usage of OptiX/OIDN imager
04:05:55 8770MB | 2: [mtoa] [%s] [node %s] Assigning temporary node id %i to associated Maya type name %s.
04:05:55 8770MB | 10: resetting parameter %s on %s (found: nans or infs)
04:05:55 8770MB | performance warnings:
04:05:55 8770MB WARNING | Scene creation time could be reduced slightly by fixing the following issues:
04:05:55 8770MB | 8 curves objects were motion blurred even though they were static.
Message 4 of 15
Unfortunately that old version doesn't show the stats. Can you use a newer version of MtoA?
If you Ignore Textures, is it still slow?
How about if you Ignore Shaders and Ignore Textures?
// Stephen Blair
Message 5 of 15
And try with CPU, please. We'll get better profiling stats with CPU
// Stephen Blair
Message 6 of 15
I'm afraid that render that frame with CPU will take extra long.
Also I'm using the old arnold version because the newest release is very buggy. 😅 As other user have noticed, all the renders rom the lagest release come out distorted and corrupted. I had no choice but scaling back a version. If there is a way to work around the corrupted renders I'll be happy to install the newest version again 😀
Message 7 of 15
thiago.ize
in reply to: giandosopaolo
Hopefully you don't need to render full resolution in order to repro this issue? If you render at 200x200 pixels do you still get a much slower render for the first frame than the following frames? If so, you can use that in your testing. If you disable adaptive sampling and use AA=1 does it also show this problem? If so, that's another thing you can do. Hopefully now you can do this testing in just a few minutes instead of hours or days...
And if this causes your slowdown to go away, then that's useful information as well.
Message 8 of 15
giandosopaolo
in reply to: thiago.ize
Hi @Stephen.Blair and @thiago.ize
I made the following experiments using the Arnold version I currently have.
  • render at 10% scale: This render faster and does not balloon on frame 1 (5 m per frame)
  • Disable adaptive sampling and use AA=1: This render faster and does not balloon on frame 1 (6 min per frame)
  • Ignore Textures: This does not render faster, actually it renders even slower (extimated 34626.1s for frame 1)
  • Ignore Shaders : This render faster and does not balloon on frame 1 (around 5 m per frame).
Message 9 of 15
thiago.ize
If you do a cpu time AOV, I wonder if it shows what is causing the expense? If lower res and lower AA are fine, then it could be a small fraction of a pixel that is super expensive?
Also, this 5m you report, is that "rendering" time or total time? You'd only want to pay attention to the rendering time since you have almost 5 minutes spent simply starting up the render.
Message 10 of 15
giandosopaolo
  • render at 10% scale= 3:41.15 render time. I checked it out in nuke and it rendered black so it does not count I guess.
  • Disable adaptive sampling and use AA=1=  1:08.23 render time.
  • Ignore Textures=This does not render faster, actually it renders even slower (extimated 34626.1s for frame 1)
  • Ignore Shaders AND Textures =  7:52.03 render time
I installed the latest arnold version now @Stephen.Blair  and tried a CPU render with the cputime AOV.
Camera AA:3, Diffuse 3, Specular 4, Transmission 2, SSS4, and Volume Indirect 1. These setting do not give as good as a result like the one produced by the GPU, but like this arnold rendered the first frame in 44 m.
However in Nuke I can not locate any AOV called cputime.
It just does not appear. There is a layer called OTHER that comes out yellow though, maybe is that one.
(Also BTW, the denoised beauty from OIDN came out corrupted).
Here below is the log.
What can I do?
Message 11 of 15
thiago.ize
If rendering at 10% scale is coming out black, then I think you have bigger issues with this scene that you need to solve. I would suggest simplifying your scene until you figure out what is the problem. I suspect that might also be the cause of your slowdown.
Did you look at the warnings in the log? nans and infs can cause all sorts of problems, including weird slowdowns. Try and fix your /Turnaround_CAM_01/Turnaround_CAM_01Shape. Or better yet, first try deleting that completely and see if it fixes your problem. If it does, then you can investigate how to fix that.
00:01:31  7459MB WARNING |  [ass] line 275: ignoring /Turnaround_CAM_01/Turnaround_CAM_01Shape.lens_tilt_angle (expected 4 values for array type VECTOR2 but found 2)
00:01:31  7460MB WARNING |  resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:31  7460MB WARNING |  [ass] line 275: /Turnaround_CAM_01/Turnaround_CAM_01Shape.-nan: unknown '-nan' parameter
00:01:31  7461MB WARNING |  [ass] line 277: ignoring /Turnaround_CAM_01/Turnaround_CAM_01Shape.lens_shift (expected 4 values for array type VECTOR2 but found 2)
00:01:31  7462MB WARNING |  [ass] line 277: /Turnaround_CAM_01/Turnaround_CAM_01Shape.-nan: unknown '-nan' parameter
00:01:31  7464MB WARNING |  resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:31  7471MB WARNING |  resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
00:01:31  7471MB WARNING |  resetting parameter matrix on /Ren_CAM/Ren_CAMShape (found: nans or infs)
00:01:31  7473MB WARNING |  resetting parameter matrix on /Turnaround_CAM_01/Turnaround_CAM_01Shape (found: nans or infs)
Message 12 of 15
giandosopaolo
I will try this tonight sure @thiago.ize, I deleted the 2 cameras that seem to give nan issues accordingly to the log (not the shot camera luckily) and I am rendering again tonight!
In the meantime @Stephen.Blair, now that I installed the latest version I managed to render one regular frame with the better Log that you mentioned before. The frame come out correct, with no distortion this time around :), but again it took hours. Maybe this new log file can give a better insight! What do you think?
Message 13 of 15
Unfortunately I don't see anything obviously wrong in the log.
We just can't tell where the time is going.
It's a GPU render, so we don't get as much stats/profiling info. That was one of the reasons for suggesting a CPU render: if CPU render was also slow for the first frame in a sequence, then the stats/profiling might help pinpoint the problem.
In general, what I do with problem scenes is try to isolate the problem:
- export an ass file and use kick (this is not for everybody, but it helps because it is actually simpler than loading maya to render a maya scene)
- render at AA -3, no adaptive; reduce the resolution, maybe do a render region (as Thiago suggested)
- start removing stuff (operators, procedurals, geometry). As long as the problem still happens, I keep simplifying...
- check whether Ignoring things changes anything
- use an operator to apply the same shader to everything, or to disable things
// Stephen Blair
Message 14 of 15
Yesterday I removed the camera 001 from the file and the standins too, unfortunately it is not the problem 😕
I attached a log of the 1st frame (5 h 26 min render time) and the log of the following frame (18m 45 sec render time).
Does this help in any way?
Message 15 of 15
thiago.ize
The log does helpfully show that most things look the same between the two frames (ray counts, etc.) with the exception of the time. As we said earlier, I think you need to simplify your scene to try to figure out what is causing this. The fact that you can't render at 10% resolution without getting black is particularly concerning.
Technology Administrators
