Error: Access violation
himinglaeva47
Message 1 of 15
himinglaeva47
Application: maya.exe Error: Access violation - code c0000005
Date/Time: 2023-10-08 16:24:05 -07:00
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: ai.dll
Exception Address: 0x00007fff95b757a0
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 1, 24b08621268
After building a rig using advanced skeleton I get this error when trying to render. I went and tested the render using a file before I started rigging and It worked fine. After that I downloaded the new update and the error is gone but the scene render black. Any ideas how to fix the problem?
Edit: fixed The black renders. Ive gone back rendering scenes and renders are fine until I start building the rig, are you not able to render with a advanced skeleton rig in your scene? I dont know what it is. lol
Thank you
Replies (14)
Message 2 of 15
himinglaeva47
Ok, the problem is you cant enable smooth mesh preview or it will crash arnold.
Message 3 of 15
lee_griggs
Are there Arnold subdivision_iterations on the mesh? This coupled with smooth mesh preview can create billions of polygons.
Can you provide a full verbosity log file?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 15
himinglaeva47
Hi, I was able to render by disabling the smooth mesh preview, my mistake.  If you would like the log I will provide it for you? Thank you for the reply Lee
Message 5 of 15
philewill
I've got pretty much this same issue, except whenever I render in Arnold it crashes regardless of smooth mesh preview, I uninstalled Maya 2024 and installed 2025 thinking maybe they fixed the bug in the new version as it was working perfectly fine a couple months ago, but to no luck. I have a 4090 so I'm pretty sure my graphics card is strong enough to handle Arnold, but alas it crashes, sometimes so quickly that the program doesn't even have time to send a crash report. For a subscription-based software, I'm appalled this is even a thing.
Message 6 of 15
himinglaeva47
Double posted sorry
Message 7 of 15
himinglaeva47
I’m not sure what it could be. You can try going through each assets and press 1 on keyboard. I render with cpu so if your rendering with gpu it could be a setting. Near the end of this video there is an explanation for gpu render settings. Hope this helps https://youtu.be/mLMXWCLX4SY?feature=shared
Message 8 of 15
philewill
thanks, I changed it to GPU, and it didn't crash, hopefully it's not a fluke and remains fixed!!!
Message 9 of 15
nixhilroy
Observer
Observer
Hey, I have got the same kind of error I guess. I installed maya 2025 version in my newly bought laptop. and after installing maya crashed with this error report.
Date/Time: 2024-07-02 22:11:51 +05:30
Crashed Module Name: ntdll.dll
Exception Address: 0x00007ff81d33492b
Exception Flags: 0
Exception Parameters: 1, 7fffa08de43c
I also tried to install older versions but the error is still there.
Message 10 of 15
celal_sonka99
Community Visitor
Community Visitor
I have the same problem dıd you solve it ?
Message 11 of 15
1419292660
Community Visitor
Community Visitor
我之前遇到过和你一样的情况,你可以试试更新主板的BIOS。电压不稳定可能是由第 13 代和第 14 代英特尔的设计缺陷引起的。自从更新 BIOS 以来,我没有遇到任何崩溃
Message 12 of 15
1419292660
Community Visitor
Community Visitor
I have experienced the same situation as you before, you can try updating the BIOS of your motherboard. It is possible that the voltage instability was caused by a design defect in the 13th and 14th generations of Intel. I have not experienced any crashes since updating the BIOS
Message 13 of 15
aligillies
I'm having the same issue.
"WARNING Signal Caught: Error C00000005 -- access violation"
I'm setting my scene up the same way I've done for years, but it crashes every time I try to render it.
Message 14 of 15
andynyc
I had the same error and ended up narrowing it down to my output resolution settings. The Maya file I received from a client had the resolution set to 1200x1729. And after much troubleshooting with smoothing levels, displacement shader settings, and importing the meshes into a clean scene, I tried rendering with a new camera with default settings and it finally started rendering without crashing Maya. So, I used another vertically-oriented preset (in this case "Letter") to get close to matching the client's dimensions and then adjusted the ppi from 300 to 72 and changed the height dim to 1730 with "Maintain width/height ratio" enabled. With that, my new resolution ended up being 1338x1730. and it rendered without issue.
Just reading this thread, it appears this error might happen for a number of reasons. In my case it was a resolution setting. So, I figured I'd share and add it to the pile of potential causes.
Just an aside:
Someday, it would be nice to see a bottom-up rebuild of Maya. I know this is a heavy lift. But I've been a Maya user before it was Maya (aka Alias Power Animator), and the stability issues seem to have increased over time. I won't use the "B" word, but it's catching up quickly. Just my 2 cents.
Message 15 of 15
thiago.ize
Folks, this error message is just a generic message saying a crash happened in arnold (ai.dll is the arnold code). Unless it's related to smooth mesh preview it's very likely completely unrelated. Please make a new thread explaining what you were doing when the crash occurred. Ideally include complete arnold logs as they can include very useful information. If the autdoesk customer error reporting tool popped up asking you to report the bug, please do it and give us the report ID. That can go a long way to letting us diagnose and fix the problem. Include your email address in the CER report and you might even get an automated email once the bug has been fixed.
