Ehy Guys, sorry to bother but I have a problem with mtoa and drivers list I can't resolve alone because it works perfectly as it should on C4D for example while on Maya it looks it may need some ad-hoc metadata or naming convention or something that apparently I don't know while I cannot find a place with info about.
Problem1 :: mtoa does not read the name (node->name = "driver_romboExr") of a driver (node->node_type = AI_NODE_DRIVER) from the Arnold loader correctly.. it looks it does rely on the library name instead.
Problem2 :: when I have more than a single driver on the same lib.. first mtoa messes up with Common tab in Render Settings. Second, in places where I can add a driver (ie. AOVs render settings tab) it looks it gets just the last driver on the list with the above mentioned lib name.
Problem3 :: parameters in an imager ain't going down the imager list block like with your other imagers but on the attribute editor.
Here the loader :
case ROMBO_RAWDRIVER_DENOISER:
node->methods = (AtNodeMethods*)romboRawDriverDenoiserMtd;
node->output_type = AI_TYPE_NONE;
node->name = "driver_romboDenoiser";
node->node_type = AI_NODE_DRIVER;
break;
case ROMBO_DRIVER_EXR:
node->methods = (AtNodeMethods*)romboDriverEXRMtd;
node->name = "driver_romboExr";
break;
case ROMBO_IMAGER_TONEMAPPER:
node->methods = (AtNodeMethods*)romboImagerTonemapperMtd;
node->name = "imager_romboTonemapper";
node->node_type = AI_NODE_IMAGER;
break;
Can you help ? Thanks.
Solved by ashley.handscomb.retallack. Go to Solution.
Looks Maya doesn't like pointers params and I just realized I don't even need them because no callbacks involved.
Removing them I got the first part of Problem2 fixed.. no more Common tab mess up.
For Imagers to have a proper UI in Maya we need to add a py script. Not sure about the naming there but one can just instanciate an imager, tweak a param there for example and then lookup the script editor to see what name has been given by Maya. There're example files in : mtoaarnold/maya2024/scripts/mtoa/ui/ae/
With that, UI params will gracefully fall into the imager UI block.
Hi Max,
Problem1:: Try setting the metadata "maya.translator" to the name of the translator you which to be displayed in the driver options menu
Problem2: are you able to share screen shots of what you are seeing?
Problem3: YUes you need to create a AE template inherting from the
