Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Create AOVS for tonemap aitoon shader
1 REPLY 1
jmoulet
94 Views, 1 Reply
Hello, I have a scene with several AItoon shaders, each with their own Tonemap. I would like to retrieve an AOVS from these TONEMAP in my beauty render.
Do you have a solution for this? I've tried creating custom AOVS in the shading group, and I discovered AIwritecolor, but I haven't yet understood how it works.
If you have any ideas or a solution to propose, I'm all ears!
(I could do it with render layers, but I'm looking for a more optimized method for cases where I have a large number of shaders)
1 REPLY 1
jmoulet
in reply to: jmoulet
I finally found a solution thanks to CHAGTP. I ended up using AiwriteColor. I created multiple instances of it, chaining them together with the information I wanted to retrieve each time. This does make the shading process a bit more complex and requires doing it for each shading group in the scene, meaning for each different shader. I suppose there's room for optimization, but at least it works! I'm thinking of scripting it now! Hopefully, this can help others too!
