Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Bifrost not rendering
5 REPLIES 5
jeffSickles3460
3511 Views, 5 Replies
I have a simple bifrost simulation that has a liquid and some foam. The liquid renders fine after exporting the mesh to alembic... the foam however doesn't render as points... or spheres... or volumes. The error I get seems to indicate that mtoa is the culprit rather than some settings problem. Here is the error I get...
// Error: Bifrost to Arnold package not installed in /Applications/Autodesk/bifrost/1.5.0/arnold-5.0.0.0/lib // // Error: [mtoa.translator] bifrostTranslator: Arnold node type bifrost_polymesh does not exist. // // Error: Bifrost to Arnold package not installed in /Applications/Autodesk/bifrost/1.5.0/arnold-5.0.0.0/lib // // Error: [mtoa.translator] bifrostTranslator: Arnold node type bifrost_points does not exist. //
Anyone have an issue like this? Is this perhaps a Maya Env/Path problem?
Maya 2018/Arnold 5
Thanks...
Tags (3)
Labels (3)
5 REPLIES 5
Do you have Maya 2018 Update 1? That installs the Bifrost to Arnold package, which you are missing.
// Stephen Blair
// Arnold Renderer Support
Boom - that did it. Thanks Stephen!
How can I render without Update 1.
MtoA 3.3.0.1 not render bifrost
i'm using maya 2018.1
and Mtoa 3.2.0 render normally
Stephen.Blair
in reply to: elmorsy_pro
Please do not answer a three-year old question with another question.
Please ask a new question and please supply an Arnold (verbosity level = Info)
// Stephen Blair
Technology Administrators
