Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
AttributeError: ProceduralWidgets.py line 21: module 'maya.cmds' has no attribute 'arnoldPlugins'
5 REPLIES 5
Natalie_Yaroslavtseva
3745 Views, 5 Replies
Hello ! Maya ver.2022.2. I have installed Arnold for Maya on Windows 10 Pro. I open my project and go to the "Arnold" tab and press the button "Render". And an error is displayed: "# Error: AttributeError: file C:\Arnold\maya2022\scripts\mtoa\ui\procview\ProceduralWidgets.py line 21: module 'maya.cmds' has no attribute 'arnoldPlugins''".
Detailed error text:
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "MASH";
// Loading Bifrost version 2.3.0.0-202107271733-fc8db84
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
updateRenderOverride;
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/autoLoadPlugin.mel line 40: Loading plug-in "mtoh" has resulted in changes to the scene that may need to be saved. //
// Warning: file: C:\Users\natal\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\natal\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\natal\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\natal\OneDrive\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// AbcExport v1.0 using Alembic 1.7.5 (built Nov 30 2020 18:40:46)
// AbcImport v1.0 using Alembic 1.7.5 (built Nov 30 2020 18:40:46)
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/others/supportRenderers.mel line 67: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. To prevent this message from being displayed in the future, set the environment variable: MAYA_NO_WARNING_FOR_MISSING_DEFAULT_RENDERER=1 //
file -f -new;
// untitled //
import mtoa.ui.arnoldmenu as arnoldmenu; arnoldmenu.arnoldMtoARenderView()
# Error: AttributeError: file C:\Arnold\maya2022\scripts\mtoa\ui\procview\ProceduralWidgets.py line 21: module 'maya.cmds' has no attribute 'arnoldPlugins' #
Please help me solve the problem !
Tags (3)
Labels (3)
5 REPLIES 5
Check the Plug-in Manager. Is mtoa loaded?
// Stephen Blair
// Arnold Renderer Support
saliha_azaz
in reply to: Stephen.Blair
Hello, i have the same problem but i have verified in my plugings and the folder mtao is here, so i don't understand how fix this probleme.
Can you help me please ?
Have a good day
Stephen.Blair
in reply to: saliha_azaz
Have a good day
In the Plug-in Manager, you see mtoa and the Loaded check box is selected?
What's printed in the Script Editor history after you start Maya? And what is printed in the Output Window?
// Stephen Blair
saliha_azaz
I don't know how i see that and i work from mac book pro so there is different display
Stephen.Blair
The script editor is the same on macOS, so you can get the script history, which will help.
// Stephen Blair
Technology Administrators
