Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Arnold swatches freeze Maya (2023.3)
2 REPLIES 2
yann.glica
157 Views, 2 Replies
Hi, even with swatches OFF, Render swatches startup uncheck and max res for swatches set to 0x0, Arnold always load swatches that make freeze hypershade and Maya with high resolution textures. Swatches are loaded and then, after several minutes of freezing, swatches are finally hidden and then we can go back to work. That's very annoying. We lost a lot of time.
In the attached document, Arnold / Maya is processing the swatches. One by one, swatches are hidden. Here i had to wait four minutes.
Is there a trick ? Can anyone do something about it ?
Labels (1)
2 REPLIES 2
lee_griggs
in reply to: yann.glica
Mine don't update when I disable it here.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_maya_system_am_Maya_Integration_html
Lee Griggs
Arnold rendering specialist
AUTODESK
yann.glica
in reply to: lee_griggs
Wouhou !
It's working ! Thks !
I just wonder why there is an OFF button on the hypershade that doesn't work and options in Preferences that doesn't work too.
But your trick works just fine 😉
