Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Arnold standin light links/groups
4 REPLIES 4
BrianHanke
1177 Views, 4 Replies
I have a USD scene I brought in via standin. Everything's working great, textures, displacement, you name it. I'd like to do a bit of light linking though and I don't understand how that works. There is a light_group option for each element in the scene, but it's not clear to me how to set groups using that interface. For example, I'd like to have lights 1 and 2 hitting the face, only light 1 on the hair, and light 3 only on the back part of the hair. Any tips? Thanks!
Tags (2)
Labels (2)
4 REPLIES 4
Stephen.Blair
in reply to: BrianHanke
A light group is an array of the lights that light the object.
The syntax looks like this:
https://answers.arnoldrenderer.com/questions/19358/light-linking-and-alembic-procedural.html
use_light_group = true
light_group = ['green_lightShape' 'ground_lightShape']
// Stephen Blair
// Arnold Renderer Support
BrianHanke
in reply to: Stephen.Blair
Thanks, but I'm still not clear on how this is implemented. See attached pic. I pared down my USD scene to just the head mesh for testing. There are two lights, left and right. use_light_group bool set to True seems to do something, it turns off all lights when enabled. But I can't figure out how to point the light_group parameter to my lights. I tried every possible method of typing it in, left, leftShape, 'left', 'leftShape', middle mouse dragging the light...
Stephen.Blair
Hi Brian
You use the name of the Arnold light node, which by default will be /left/leftShape
and
You have to use the syntax that I showed.
// Stephen Blair
BrianHanke
Ah, working perfectly now, thanks! I was missing the full address of the lights.
