Arnold 5.1 and the displacement
Hello in the version 3.0 something changed for the displacement because maintaining my mesh are inflated as balloons while with the version 2.1.0.3 I have no problem.
I find nothing in doc concerning this change
lee_griggs
It is working fine here. I added an example scene here for you to test. Can you test it to see if you get the same results? If not, can you post images and/or simple scene of what you are seeing?
Lee Griggs
Arnold rendering specialist
AUTODESK
This is what I obtain with my mesh
- First embellish with images arnold 3.0.1
- Second embellish with images arnold 2.1.0.3
The second image is corecte and I can modify the scale with no problem at all
A former(old) project with arnold 2.1.0.3 All goes well
The same project with arnold 3.0.1 The same map without modifying anything
