Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
AOV with aitoon shader - can't set contour and no contour properly
1 REPLY 1
756 Views, 1 Reply
Basically, I want to isolate both the contour alpha and everything else from my aitoon shader in their own AOV renders.
Like this https://docs.arnoldrenderer.com/pages/viewpage.action?pageId=71008401
But I don't know how to set up the shader or the AOVs properly. Could someone explain to me how to set them up?
Thank you.
Tags (4)
Labels (4)
1 REPLY 1
I got the solution : I just added a Diffuse AOV along with another one - any type will do - and then isolated the alpha channel, which has a contour filter on it.
The diffuse having a box filter.
Hope this can help you, should you see the same problem.
Technology Administrators
