Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
aov's pass for Beauty
2 REPLIES 2
info
5853 Views, 2 Replies
Hello, someone can tell me the list of aov's for recreate a beauty pass in maya and arnold 5 with AistandardSurface? thank you
Tags (2)
Labels (2)
2 REPLIES 2
Stephen.Blair
in reply to: info
https://support.solidangle.com/x/rQAnAg
Composing the Beauty AOV
The RGBA beauty AOV can be split into smaller AOVs where each contains part of the lighting. In compositing these AOVs can then be individually modified and added together to get the full beauty AOV.
More AOVs give more control in compositing, but also extra work to handle, and they take up more memory and disk space, especially combined with light groups.
Some example sets of additive AOVs for the full beauty AOV are:
  • direct, indirect, emission, background
  • diffuse, specular, coat, transmission, sss, volume, emission, background
  • diffuse_direct, diffuse_indirect, specular_direct, specular_indirect, coat, transmission, sss, volume, emission, background
Simply adding together such AOVs is all that is needed for the beauty AOV. The albedo AOVs are not needed to reconstruct the beauty AOV, but may be used for example to get just the lighting without the surface texture, by dividing diffuse by diffuse_albedo, or for denoising just the lighting while keeping the texture detail intact.
// Stephen Blair
// Arnold Renderer Support
info
in reply to: Stephen.Blair
thank you very much
