I'm trying to make my model transparent with an AiToon shader. I just updated to Maya 2020. I'm using a contour filter. I've disabled opaque on the model. I've set transmission weight to 0.7.
When I render, the model is not transparent. What am I doing wrong?
Solved by phoebemao2014. Go to Solution.
It seems to be working fine for me. Can you share your settings/renders/scene files (see text on right)?
Can you upload the scene somewhere? Is Energy Conserving enabled?
Hi Nick, remember to put the specular weight to 1. I almost missed this step as well. I don't know if you already fixed this, but I want to mention this part in case anyone has the same issue 🙂
