Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
AiToon transparency/transmission not rendering as transparent
6 REPLIES 6
1362 Views, 6 Replies
I'm trying to make my model transparent with an AiToon shader. I just updated to Maya 2020. I'm using a contour filter. I've disabled opaque on the model. I've set transmission weight to 0.7.
When I render, the model is not transparent. What am I doing wrong?
Labels (3)
6 REPLIES 6
lee_griggs
It seems to be working fine for me. Can you share your settings/renders/scene files (see text on right)?
Lee Griggs
Arnold rendering specialist
AUTODESK
Here it is.
in reply to: lee_griggs
Here it is.
lee_griggs
Can you upload the scene somewhere? Is Energy Conserving enabled?
Lee Griggs
AUTODESK
phoebemao2014
Hi Nick, remember to put the specular weight to 1. I almost missed this step as well. I don't know if you already fixed this, but I want to mention this part in case anyone has the same issue 🙂
in reply to: phoebemao2014
It worked. Thanks!
