I just noticed that the aiImage node doesn't seem to filter correctly (or just not?).
I created a plane, assigned an aiFlat material with a gras texture and switched between the maya native "file [texture]" node and the arnold aiImage node. The maya native one seems to render much smoother (correctly) in the distance.
I tried adjusting all settings in the aiImage node, but nothing seems to change anything. Is this expected behaviour?
Render settings - Camera (AA) = 3
Solved by thiago.ize. Go to Solution.
A Maya file node is replaced with an aiImage at render time.
Export the shader tree with a Maya file node and then re-import. You'll get an aiImage with probably some other nodes connected (eg to replace the place2Dtexture)
thanks for the reply.
I don't know if you have some special export/import settings, but my file texture node won't be replaced with an aiImage node.
does your aiImage node not produce noisy results at 3 Camera (AA)?
Even on 8 Camera (AA) settings the aiImage node produces a bit noisy results on the horizon line of the plane for me and that isn't reasonable when I try to render animations.
Post your scene here, along with the texture, and maybe someone can take a quick look to see if there's any obvious issues. In theory, the arnold image node should work properly and not be noisy at AA=3.
thx for the reply.
I attached a maya 2020 binary and ASCII file. The persp camera has a bookmark. I left out the image itself, you would have to repath them anyway and the effect should be ovbvious with any file. I added an aiSwitch node for a side by side comparison, feel free to attach the texture outputs directly to the aiFlat shader.
Also, thanks Autodesk... again:
Autodesk Forum:The attachment's texture_noisy_aiimage_maya2020.mb content type (application/octet-stream) does not match its file extension and has been removed.
So that's why I attached a zipfile too with the *.mb file...
I exported your scene to a .ass file to see what is really being fed to Arnold, and as Stephen said, under the hood mtoa is using an Arnold image node for both versions. The reason the right side has all that noise is that the image node has its uvcoords param set to the place2dTexture. When uvcoords are set, it means Arnold can no longer compute the uv texture differentials and the highest res mipmap of the texture is used and we get this noise that only goes away with really high camera sample rates. Here's what it looks like in the .ass file. Note how the uv_transform is fed into the image node's uvcoords:
name aiImage1
filename "your_texture.tx"
uvcoords place2dTexture1
uv_transform
name place2dTexture1
repeat 5000 5000
The left side, which has no noise does the opposite, the image is instead fed into the uv_transform, which is then passed to your switch shader:
name file1
uv_transform
name file1/uv
passthrough file1
repeat 5000 5000
So, that's what is going on under the hood. The question on our end is why does one way do the good method and the other way does the not at all good method. I'll report back if I can find more info on this. Thanks for bringing it to our attention!
By the way, for those interested, the optimal solution would be to do everything in the image node. In this case not only does it do the proper filtering, but it'll be slightly faster (barely a fraction of a percent) since it just evaluates one node instead of two nodes:
name aiImage1
sscale 5000
tscale 5000
@thiago.ize wrote:[...] When uvcoords are set, it means Arnold can no longer compute the uv texture differentials [...]
Ah, I see. That's the reason why there is an aiUVTransform node. I think it can manipulate the coordinates and preserve the differential calulation. I am actually trying to deforming the UV coordinates and wanted to use world space coordinates, but I guess I have to stick to UV space if I want smooth texture sampling.
Thank you so much for the effort.
