Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
4.0.4 renderview issue MtoA
2 REPLIES 2
Parmenides
325 Views, 2 Replies
I upgraded to MtoA 4.0.4 but Arnold Renderview play button is grayed out. I deleted my Maya preferences and it went away but the issues resurfaces the next time I open a new project.
Went back to 3.0.4.1 and everything works fine.
Mac/OS 10.15.6 /MacPro 2019/Maya 2020.2
Tags (1)
Labels (1)
2 REPLIES 2
Hi Derryl, I can't reproduce this issue on my side.
By checking the code the only situation where the play button is greyed out should be if you're currently displaying a snapshot. Does it give you a hint on what could be going wrong in your setup so that I try to reproduce it here ?
Are you using a snapshots folder ?
Otherwise, whenever you have the issue, before you delete your preferences, you can open them in a text editor, look for the section about the arnold renderview and copy it here.
You can also write us at support@arnoldrenderer.com if you need to share other data.
Parmenides
in reply to: Parmenides
Hello Sebastien, I am not using a snapshots folder. I have already downgraded my Arnold install so I can't tell you much more but if I upgrade again I will update you. Thanks.
Technology Administrators
