Arnold for Katana Forum
Rendering with Arnold in Katana using the KtoA plug-in.
Suppressing / Truncating Logging of (Instanced) Lights
6 REPLIES 6
Matthew_Hicks
602 Views, 6 Replies
Is there a way to adjust the logging level or otherwise suppress or truncate the individual logging of (instanced) lights?
I have an environment I'm trying to render with what I'll describe as having a "significant number" of instanced lights, and am finding that OpenImageIO/imageinput.cpp will barf occasionally:
failed assertion ... "Accumulated error messages > 16MB. Try checking the return codes!".
I'm assuming the 'accumulated error messages' are a reference to the log size, and the thousands on thousands of instanced lights reporting their status is the issue - certainly, they seem to be 95% of the log's contents.
My options to reduce the instance count are limited, but even if I'm looking at the wrong thing being able to truncate their repeated entry would make reading the log easier short of feeding it through grep -v.
Cheers,
Matt
Labels (4)
6 REPLIES 6
What's being logged for the lights? Just that failed assertion?
// Stephen Blair
// Arnold Renderer Support
Hi Stephen,
I think it's the arnoldLightShader announcing the pointcloud point it's being instanced on, the scene graph location of the instanced source geo the arnoldLightShader is on, and it's sample settings.
The format looks like
<timestamp> [INFO python.RenderLog] <Render time> <memory> <pointcloud:pointnum>:<scenegraph_location>:arnoldLightShader: spot_light using 1 sample, 2 volume samples
Individually it's definitely useful as a sanity check, but en masse the utility of the information being imparted diminishes rapidly, particularly if they're from the same instance source. Being able to set a truncate level of say, the first or last 5 or so would make it a lot more manageable.
Hi @
Ok, I get it. It's these messages:
00:00:00   566MB         | updating 25 nodes ...
00:00:00   567MB         |  /pointLight10/pointLightShape10: point_light using 1 sample, 2 volume samples
00:00:00   567MB         |  /pointLight8/pointLightShape8: point_light using 1 sample, 2 volume samples
00:00:00   567MB         |  /pointLight2/pointLightShape2: point_light using 1 sample, 2 volume samples
Arnold doesn't support light instancing, so they are all actual lights.
But like with Warnings, there could be something like Max Node Update Messages. I'll open an enhancement request.
Just curious, how many nodes are there?
// Stephen Blair
The "Accumulated error messages > 16MB. Try checking the return codes!" would be something else. Are these textured lights?
// Stephen Blair
I don't seem to have lines telling me how many nodes are being updated. Maybe that's a local config thing. Either way, I'm on katana 3.2.3, ktoa 2.4.0.5, arnold 5.4.0.2.
In the log of a successful render, there are:
45894 lines total
45261 lines of arnoldLightShader details, of which
44773 lines are associated with an 'instancer' element, where
23011 lines are spot_lights, and
21762 lines are point_lights
There seems to be at least 21 kinds of 'light' asset in the element, with at least one creating ~4000 copies.
Thanks for the tips on the textures and info on Arnold light 'instancing'. I'll have to look into that to see if any are being applied in the instancer, but there will almost certainly be textures applied on many of the 'non-instancer' lights.
Is there anything related to the textures I should be looking for?
thiago.ize
in reply to: Matthew_Hicks
The just released Arnold 6.2.0.0 has the following fix which might interest you:
Limit number of per-light log messages: If there are more than 100 lights, we stop outputting per-light sampling log messages at the regular log verbosity and instead only output these at debug level verbosity. This should help avoid "spamming" the logs when there are many lights in a scene (core#10098).
More details on that release are availableat https://docs.arnoldrenderer.com/display/A5ARP/6.2.0.0. You can download it from https://www.arnoldrenderer.com/arnold/download/
However, the "OpenImageIO/imageinput.cpp" error message has to do with texturing and is not related to these light messages. If this error message goes away after reducing the number of lights, then perhaps it's because these are textured lights? Otherwise it's something else texture related in your scene. Either way, can you provide us with a scene (as simplified as possible) that reproduces this so that we can then try and fix it?
