Merged AOVs in RenderOutputDefine keeps failing on ktoa
This widget could not be displayed.
Hello everyone,
Everytime I try to disk render my scene with ktoa, the renders fail on the last RenderOutputDefine which is the merge one. I already checked the "How to create multichannel output in KtoA?" topic but it wasn't helping.
The error is:
Running command: 'C:\Program Files\Katana4.0v5\bin\ExrCombine' 'C:/Users/Utilisateur/images/TEST/specular_0100.exr' specular 'C:/Users/Utilisateur/images/TEST/diffuse_0100.exr' diffuse 'C:/Users/Utilisateur/images/TEST/merge_0100.exr'
Render stopped with exit code: -1073740940
CommandLineRender Error: Render stopped with exit code: -1073740940
Render error. Time elapsed: 19.51 s
Node 'Render1': Render1 failed with a rendering error: Render stopped with exit code: -1073740940
All my file extensions are exr, all the types are raw and I unchecked the tiled option for every ArnoldOuputChannelDefine.
Is that connected to the fact that after every output there's the name like specular, but after the merge one there isn't anything?
I do apologize if the issue has already been resolved but I couldn't find any answer.
Thanks in advance!
Stephen.Blair
ExrCombine is a post-render process. The Arnold render itself finished successfully, it's the the Katana utility ExrCombine that fails.
Perhaps it is this?
https://support.foundry.com/hc/en-us/articles/360000201530-Q100384-Render-fails-when-merging-channel...
// Stephen Blair
// Arnold Renderer Support
