Message 1 of 1
Failed to generate merged AOVs EXR image
Hello Team,
I’m trying to generate a merged AOV EXR image using a simple test scene, but I keep running into the following error:
Render stopped with exit code: -1073740791
CommandLineRender Error: Render stopped with exit code: -1073740791
Other than the exit code, there isn’t much information indicating what actually caused the failure, so I’m not sure where the issue is coming from.
I’ve already followed the setup recommended in the Katana documentation, and I also checked that the data windows are consistent across all AOV outputs.
Could you please help check whether I’m missing any required settings in the uploaded scene? Thanks!
