Arnold for Katana Forum
Rendering with Arnold in Katana using the KtoA plug-in.
Args file widget mapper error Katana 4
4 REPLIES 4
505 Views, 4 Replies
Hi
all widget mapper return error in most DCC except RenderMan
is there a way to fix this issue?
Tags (2)
Labels (2)
4 REPLIES 4
pal.mezei
Hi Rachid!
At the moment there is no ktoa release available for Katana 4.0. We are working on it, I'll let you know once it's available.
Cheers,
Pal.
Hi Pal Mezei
Thank you, I finally corrected all the Args files for Katana 4, it took me a day to do all of them.
I can share if anyone is interesed
pal.mezei
Hi!
I'm sorry you had to spend time on it, but this can be fixed by changing the C++ plugin. The fix for this is going to be included in the upcoming KtoA 3.1.1.0 release.
nice, I hope with C++ plugin you can fix the naming convention like in layer_rgba
layer_1
enable1
name1
input1
operation1
mix1
layer_2
enable2
name2
input2
operation2
mix2
to
layer_1
enable
name
input
operation
mix
layer_2
enable
name
input
operation
mix
