Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Writing ASS for crowd
3 REPLIES 3
CyrilCosta
325 Views, 3 Replies
I'm trying to find a workflow for crowd rendering with Arnold/Houdini
(I'm using Arnold HtoA 6.1.4.3 (arnold 7.1.4.3) on Houdini 19.5.493)
But it gives me headacke !
The agent system of houdini is a special packed primitives.
When I run a simulation and try to save the caches to .ass file, all the meshes of ALL the agents are writting inside the .ass file.
Is there a way or any tricks to keep instances with a crowd setup into an arnold procedural ?
I need to render very massive crowds with HD agents, and that's impossible if it's unpacked geometry. Houdini crashes due to ram issue.
Thanks for help, I can't find solved topic about that !
Tags (3)
3 REPLIES 3
kimuayum
in reply to: CyrilCosta
I am also having the same problem.
Have you found a solution here since then?
CyrilCosta
in reply to: kimuayum
Yes, I ran into usd / solaris.
The cache files go from 30go per frame to 800Mo. But it was a pretty massive workflow, lot of RND and dev to create all proper render settings, aovs, etc.
I spent month on it.
But you can stay in /obj/ and try splitting your crowd into different parts, use LODs and camera frustrum, try to use same models with different textures.
Good luck  😉
kimuayum
Thanks for getting back to me so quickly.
I see that you use usd/solaris.
Just knowing that ASS can't do that is a step in the right direction.
As for usd/solaris,
I'll take this as an opportunity to try it.
I will take this opportunity to try it.
Thank you very much.
