Why cannot the Arnold renderer be used in the "solaris" system to create cartoon effects and render the edges of objects?
1811266997
1811266997
Community Visitor
Community Visitor
I added a "render var" node to "solaris" and created a "contour filter", but still couldn't render the edges of the object.
When I am not in the 'solaris' system, the Arnold renderer can render the edges of the object normally.
I want to know where the problem is, thank you.
peterDTE7K
Toon shader seems to work but this is rather a filter problem. There are 3 places where you can set filter but none of them works correctly
1. Render Var - doesn't work
2. Arnold Standard Rendervars - doesn't work and you cannot change filter width
3. Arnold Render Settings (file output > AOVs tab) - you cannot change filter width and the filter on the first AOV does not work. You need to add second beauty RGBA AOV and preview this AOV in Solaris render view
