Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Warning: some output paths were ignored, since outputs always follow the input file layout.
3 REPLIES 3
272 Views, 3 Replies
Trying to run Noice from command line in linux, we get
"Warning: some output paths were ignored, since outputs always follow the input file layout."
Any time we run it. What does this warning pertain to? The denoiser then outputs absolutely nothing.
Tags (1)
Labels (1)
3 REPLIES 3
Stephen.Blair
Too many -o flags is the easiest way to get that warning.
Can you post the full noice command line that you run, and everything that is output to the terminal by noice?
// Stephen Blair
// Arnold Renderer Support
in reply to: Stephen.Blair
It seems that if we remove cryptomattes from the aovs it works again. Is this because of how cryptomattes modify the metadata in exrs?
Stephen.Blair
Cryptomatte changes the Arnold output statements, and that can cause problems.
Do you have multiple cameras?
https://answers.arnoldrenderer.com/questions/21129/noice-not-working-when-adding-cryptomatte-aovs.ht...
// Stephen Blair
